Update Issues "unknown trust"
Hey Ive came across the same issue i had a while ago but unfortunately lost track of how to solve it.
Basically the system is running fine (as for what i can say) but i’d like to make sure its updated.
╰─λ garuda-inxi
Kernel: 6.8.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@_backup_20232602173012259/boot/vmlinuz-linux-zen
root=UUID=233ffc2e-5048-424c-b13a-76972777141e rw
rootflags=subvol=@_backup_20232602173012259 quiet quiet
Desktop: KDE Plasma v: 6.0.3 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: Dell product: Inspiron 7577 v: N/A
Mobo: Dell model: 0WTYKT v: A00 serial: <superuser required> part-nu: 07FA
uuid: <superuser required> UEFI: Dell v: 1.17.0 date: 03/18/2022
ID-1: BAT0 charge: 7.4 Wh (100.0%) condition: 7.4/56.0 Wh (13.3%)
volts: 17.1 min: 15.2 model: Samsung SDI DELL W7NKD81 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
desc: 1x6 MiB
Speed (MHz): avg: 3208 high: 3289 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 3181 2: 3289 3: 3163
4: 3199 bogomips: 19999
Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell
driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8d
class-ID: 0302
Device-3: Realtek Integrated_Webcam_HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:5 chip-ID: 0bda:5652
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia wayland: drv: iris x11: drv: iris inactive: gbm,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.4-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
device-ID: 8086:591b memory: 7.44 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 8 device: 0 type: integrated-gpu name: Intel
HD Graphics 630 (KBL GT2) driver: mesa intel v: 24.0.4-arch1.2
device-ID: 8086:591b surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce GTX 1050 driver: nvidia v: 550.67
device-ID: 10de:1c8d surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.0.4-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
API: ALSA v: k6.8.2-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pw-jack type: plugin
vendor: Dell RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 3b:00.0 chip-ID: 10ec:8168
IF: enp59s0 state: down mac: <filter>
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 3c:00.0 chip-ID: 8086:24fd
IF: wlp60s0 state: up mac: <filter>
Info: services: NetworkManager, smbd, systemd-networkd,
systemd-timesyncd, wpa_supplicant
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 8087:0a2b
v: 3.0 port: f060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 931.51 GiB used: 539.82 GiB (58.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LX015-1U7172
tech: HDD rpm: 5400 serial: <filter> fw-rev: SDM2 scheme: GPT
ID-1: / raw-size: 689.1 GiB size: 689.1 GiB (100.00%)
used: 539.72 GiB (78.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 6.8 MiB (2.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 689.1 GiB size: 689.1 GiB (100.00%)
ID-4: /var/log raw-size: 689.1 GiB size: 689.1 GiB (100.00%)
ID-5: /var/tmp raw-size: 689.1 GiB size: 689.1 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.62 GiB used: 3.61 GiB (47.3%)
System Temperatures: cpu: 55.0 C pch: 44.5 C mobo: 46.0 C sodimm: SODIMM C
Fan Speeds (rpm): cpu: 2245
Memory: total: 8 GiB available: 7.62 GiB used: 4.06 GiB (53.2%)
Processes: 264 Power: uptime: 16h 6m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.01 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2295 libs: 604 tools: octopi,pamac,paru
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Fehler: blackarch: signature from "Levon 'noptrix' Kayan (BlackArch Developer) <noptrix@nullsecurity.net>" is unknown trust
Garuda (2.6.23-1):
System install date:     2022-12-20
Last full system update: 2024-04-04
Is partially upgraded:   Yes
Failed units:            systemd-networkd-wait-online.service
any ideas ?
thank you guys for helping me, some germany-based falconer who has installed garuda mainly because of games and its “raptor”-themed appearance :slight_smile:
Is this it?
In case of further troubles, please provide the full output of a
garuda-update
PS:
Your system is terribly outdated
So updating it might be a challenge :crossed_fingers:
