Dependency break when using update:
[sudo] password for can:
resolving dependencies...
:: installing libsndfile (1.1.0-2) breaks dependency 'libsndfile=1.0.31' required by lib32-libsndfile
root=UUID=7d76c00e-7358-4f00-a876-1486077522a6 rw rootflags=subvol=@
cgroup_enable=memory swapaccount=1 quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 cgroup_enable=memory swapaccount=1
systemd.unified_cgroup_hierarchy=0 loglevel=3
Type: Desktop Mobo: Micro-Star model: B450M PRO-M2 MAX (MS-7B84) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.70
date: 06/10/2020
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3771 high: 4414 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4293 2: 3598
3: 3605 4: 3591 5: 4414 6: 4233 7: 4249 8: 3600 9: 3590 10: 3582 11: 3599
12: 3581 13: 3605 14: 3600 15: 3604 16: 3602 bogomips: 124805
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 29:00.0 chip-ID: 10de:1f82 class-ID: 0300
Device-2: Sunplus Innovation FULL HD webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-5:3 chip-ID: 1bcf:2283
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 4920x2280 s-dpi: 156 s-size: 801x371mm (31.54x14.61")
s-diag: 883mm (34.75")
Monitor-1: DP-0 pos: primary,top-right res: 3840x2160 hz: 60 dpi: 161
size: 607x345mm (23.9x13.58") diag: 698mm (27.49") modes: N/A
Monitor-2: DP-2 pos: bottom-l res: 1080x1920 hz: 60 dpi: 96
size: 286x509mm (11.26x20.04") diag: 584mm (22.99") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 29:00.1 chip-ID: 10de:10fa class-ID: 0403
bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Sunplus Innovation FULL HD webcam type: USB
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
bus-ID: 1-3:2 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 5.46 TiB used: 228.09 GiB (4.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: S5Z42105
temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000DM004-2CV104
type: HDD rpm: 5425 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
used: 96.89 GiB (55.1%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
used: 26.7 MiB (27.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 273.44 GiB size: 273.44 GiB (100.00%)
used: 131.17 GiB (48.0%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
ID-5: /var/tmp raw-size: 175.78 GiB size: 175.78 GiB (100.00%)
ID-1: swap-1 type: partition size: 15.82 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.36 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.0 C mobo: N/A gpu: nvidia temp: 42 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1439 fan-3: 0 fan-4: 0 fan-5: 0
gpu: nvidia fan: 30%
Processes: 444 Uptime: 22m wakeups: 0 Memory: 31.36 GiB
used: 5.88 GiB (18.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 2648 lib: 575 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2021-10-25
Last full system update: 2022-04-01
Failed units: fancontrol.service memavaild.service systemd-oomd.sock
et
