Kernel: 6.1.54.15.realtime1-2-rt-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: tsc available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-rt-lts
root=UUID=b8c044ba-3855-4296-80c1-38218b0791fd rw rootflags=subvol=@ quiet quiet
Console: pty pts/1 DM: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Compulab model: fitlet2 v: 1.31 serial: <filter> UEFI: American Megatrends
v: FLT2.TPM.0.46.02.01 date: 05/24/2021
Info: model: Intel Atom E3950 bits: 64 type: MCP arch: Goldmont level: v2 built: 2016
process: Intel 14nm family: 6 model-id: 0x5C (92) stepping: 9 microcode: 0x48
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB desc: d-4x24 KiB; i-4x32 KiB
L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 1611 high: 1916 min/max: 800/2000 base/boost: 1600/2400 scaling:
driver: intel_cpufreq governor: schedutil volts: 1.2 V ext-clock: 100 MHz cores: 1: 1637 2: 1295
3: 1599 4: 1916 bogomips: 12748
Device-1: Intel Apollo Lake [HD Graphics 505] driver: i915 v: kernel arch: Gen-9
process: Intel 14n built: 2015-16 ports: active: HDMI-A-1,HDMI-A-2 empty: DP-1 bus-ID: 00:02.0
chip-ID: 8086:5a84 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.8 compositor: xfwm driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 tty: 117x26
Monitor-1: HDMI-A-1 model: HP 25es serial: <filter> built: 2017 res: 1920x1080 dpi: 88
gamma: 1.2 size: 553x309mm (21.77x12.17") diag: 633mm (24.9") ratio: 16:9 modes: max: 1920x1080
min: 720x400
Monitor-2: HDMI-A-2 model: HP 25es serial: <filter> built: 2018 res: 1920x1080 dpi: 88
min: 720x400
API: Vulkan v: 1.3.264 layers: 5 device: 0 type: integrated-gpu name: Intel HD Graphics 505
(APL 3) driver: mesa intel v: 23.2.1-arch1.2 device-ID: 8086:5a84 surfaces: N/A device: 1
type: cpu name: llvmpipe (LLVM 16.0.6 128 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM
16.0.6) device-ID: 10005:0000 surfaces: N/A
API: OpenGL Message: GL data unavailable in console, glxinfo missing.
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_apl
bus-ID: 00:0e.0 chip-ID: 8086:5a98 class-ID: 0403
API: ALSA v: k6.1.54.15.realtime1-2-rt-lts status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.80 status: n/a (root, process) with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack
type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 01:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-3: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: c000 bus-ID: 03:00.0 chip-ID: 8086:1539 class-ID: 0200
IF-ID-1: eno1 state: down mac: <filter>
Local Storage: total: 119.24 GiB used: 25.82 GiB (21.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: BIWIN model: SSD size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 2A scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 25.82 GiB (21.7%) fs: btrfs
block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 25.82 GiB (21.7%) fs: btrfs
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 25.82 GiB (21.7%)
fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%) used: 25.82 GiB (21.7%)
ID-1: swap-1 type: zram size: 7.4 GiB used: 20.5 MiB (0.3%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
System Temperatures: cpu: 47.0 C mobo: N/A
Processes: 315 Uptime: 2d 2h 28m wakeups: 0 Memory: total: 8 GiB available: 7.4 GiB
used: 2.99 GiB (40.4%) igpu: 256 MiB Init: systemd v: 254 default: graphical tool: systemctl
Compilers: gcc: 13.2.1 Packages: pm: pacman pkgs: 1494 libs: 406 tools: pamac,paru Shell: Bash
v: 5.1.16 running-in: pty pts/1 inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-03-10
Last full system update: 2023-10-05 ↻
Is partially upgraded: Yes
installing dav1d (1.3.0-1) breaks dependency 'libdav1d.so=6-64' required by ffmpeg-git
sudo pacman -Rdd dav1d
Paket (1) Alte Version Netto-Veränderung
dav1d 1.2.1-1 -1,76 MiB
upd
Packages (10) dav1d-1.3.0-1 electron24-24.8.5-2
element-desktop-nightly-bin-2023100601-1 ffmpeg4.4-4.4.4-2
fluidsynth-2.3.4-1 libavif-1.0.1-2 libheif-1.16.2-2
python-setproctitle-1.3.3-1 vapoursynth-git-R64.10.g8bd7e102-1
vlc-3.0.18-17
Total Download Size: 205.98 MiB
Total Installed Size: 661.70 MiB
Net Upgrade Size: 1.78 MiB
Hi! Thanks for quick response. YES! It did fix the update problem. Thank you!
