Update BSPWM system
First of all sorry as my question is old and I know that support from Garuda Linux to BSPWM is now over.
But I can't find any other os like Garuda BSPWM configuration. It's just awesome.
Now my question is how can I update this os ?
I tried two times but it's failed.
I really need your help.
Thanks in advance.
As you said, we don't support BSPWM anymore... you're on your own of updating and maintaining theming and everything.
won't the packages still be maintained in arch repos? although it isn't supported by garuda explicitly anymore but that shouldn't mean it can't use garuda-update anymore. both the chaotic aur and arch repos are still open to you even if you don't use garuda at all so I don't see the issue here.
Even if not officially supported, always provide terminal text. Maybe it's something trivial...
When I use garuda-update below error showing :
error : failed to synchronize all database (no server configured for repository)
warning : database file for garuda does not exist
error : target not found : garuda-hotfixes
I'd try
update remote fix
I trying your solution but what should I do for following ?
Replace atk with extra/at-spi2-core? [Y/n]
Replace crda with core/wireless-regdb? [Y/n]
Replace nerd-fonts-fantasque-sans-mono with extra/ttf-fantasque-nerd? [Y/n]
garuda-common-settings and ipw2100-fw are in conflict. Remove ipw2100-fw? [y/N]
garuda-common-settings and ipw2200-fw are in conflict. Remove ipw2200-fw? [y/N]
wireplumber and pipewire-media-session are in conflict. Remove pipewire-media-session? [y/N]
update remote fix
This is not wotking
Try with all yes for the questions above
Then below error showing (See last line)
Total Download Size:   1744.32 MiB
Total Installed Size:  6941.89 MiB
Net Upgrade Size:      1312.80 MiB
:: Retrieving packages...
 linux-zen-6.3.5.zen1-1-x86_64.pkg.tar.zst failed to download
 linux-firmware-20230404.2e92a49f-1-any.pkg.tar.zst failed to download
 firedragon-112.0.2-1-x86_64                           76.9 MiB  3.92 MiB/s 00:20 [----------------------------------------------] 100%
 garuda-wallpapers-r85.f5daed8-1-any                   63.2 MiB  2.37 MiB/s 00:27 [----------------------------------------------] 100%
 tela-circle-icon-theme-git-2023.04.16.r19.g49ae...    81.9 MiB  2.95 MiB/s 00:28 [----------------------------------------------] 100%
 Total (   5/1089)                                   1744.3 MiB  29.7 MiB/s 00:59 [----------------------------------------------] 100%
error: failed retrieving file 'linux-zen-6.3.5.zen1-1-x86_64.pkg.tar.zst' from mirrors.kernel.org : Failed to connect to mirrors.kernel.org port 80 after 5203 ms: Connection timed out
error: failed retrieving file 'linux-firmware-20230404.2e92a49f-1-any.pkg.tar.zst' from mirrors.kernel.org : Failed to connect to mirrors.kernel.org port 80 after 5202 ms: Connection timed out
error: failed retrieving file 'firedragon-112.0.2-1-x86_64.pkg.tar.zst' from cdn-mirror.chaotic.cx : Failed to connect to cdn-mirror.chaotic.cx port 443 after 9065 ms: Connection timed out
error: failed retrieving file 'garuda-wallpapers-r85.f5daed8-1-any.pkg.tar.zst' from cdn-mirror.chaotic.cx : Failed to connect to cdn-mirror.chaotic.cx port 443 after 9834 ms: Connection timed out
error: failed retrieving file 'tela-circle-icon-theme-git-2023.04.16.r19.g49aebe1c-1-any.pkg.tar.zst' from cdn-mirror.chaotic.cx : Connection timeout after 10000 ms
warning: too many errors from cdn-mirror.chaotic.cx, skipping for the remainder of this transaction
error: failed retrieving file 'linux-zen-6.3.5.zen1-1-x86_64.pkg.tar.zst' from mirror.rackspace.com : Connection timeout after 10000 ms
error: failed retrieving file 'linux-firmware-20230404.2e92a49f-1-any.pkg.tar.zst' from mirror.rackspace.com : Connection timeout after 10000 ms
error: failed retrieving file 'garuda-wallpapers-r85.f5daed8-1-any.pkg.tar.zst' from geo-mirror.chaotic.cx : Failed to connect to geo-mirror.chaotic.cx port 443 after 9062 ms: Connection timed out
error: failed retrieving file 'firedragon-112.0.2-1-x86_64.pkg.tar.zst' from geo-mirror.chaotic.cx : Connection timeout after 10000 ms
error: failed retrieving file 'tela-circle-icon-theme-git-2023.04.16.r19.g49aebe1c-1-any.pkg.tar.zst' from geo-mirror.chaotic.cx : Connection timeout after 10001 ms
warning: too many errors from geo-mirror.chaotic.cx, skipping for the remainder of this transaction
warning: too many errors from mirror.rackspace.com, skipping for the remainder of this transaction
error: failed retrieving file 'garuda-wallpapers-r85.f5daed8-1-any.pkg.tar.zst' from au-mirror.chaotic.cx : Failed to connect to au-mirror.chaotic.cx port 443 after 9064 ms: Connection timed out
error: failed retrieving file 'firedragon-112.0.2-1-x86_64.pkg.tar.zst' from au-mirror.chaotic.cx : Failed to connect to au-mirror.chaotic.cx port 443 after 9833 ms: Connection timed out
error: failed retrieving file 'tela-circle-icon-theme-git-2023.04.16.r19.g49aebe1c-1-any.pkg.tar.zst' from au-mirror.chaotic.cx : Connection timeout after 10001 ms
warning: too many errors from au-mirror.chaotic.cx, skipping for the remainder of this transaction
warning: failed to retrieve some files
error: failed to commit transaction (unexpected error)
Strange. Too many connectivity errors.
Do you have a good connection in general?
You could try later.
The pacman.conf should be ok now, so you could try a normal garuda-update
If not working, with the same or similar errors, you could try removing some of the used mirrors: Edit /etc/pacman.d/chaotic-mirrorlist and put a comment (#) before
It seems like you haven't updated for a long time how about trying
update remote keyring
It should update arch and chaotic keyring and then proceed to update your system.
update remote fix
already includes the keyring update inside.
I still hope it is a temporary connectivity issue...
I will try.
