Update broke half of my KDE theming I had going, how to reset/restore?
Just updated today after some dunno 2-3 weeks without.
Out of KDE’s System Settings’ Colors & Themes categories —
  • what no longer works: Colors, Application Style, Icons
  • what still works: Window Decorations, Night Light, Plasma Style, Cursors, Splash Screen, Login Screen
“No longer works” meaning: can be selected/applied but is just ignored and not rendered. It falls back to some mostly-white bright coloring, not even selecting the factory-defaults “Breeze Dark” theme changes Colors or Application Style.
(And Dolphin somehow shows red-like-Ubuntu-uses folder icons, I have no such Icon Theme even installed!?)
Any ideas how this KDE theming stuff can be reset/fixed without reverting to snapshot? I’m thinking maybe I should clean up some hidden-somewhere “custom themes” folders and reinstall them clean. Maybe they are now seen as corrupted and bork the works even with Garuda’s factory-default Themes… dunno?
Muchos gracias for all ideas =)
  Kernel: 6.9.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=1868f654-2472-42d9-bd68-c77b7deb3d50 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.3.0
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Laptop System: LENOVO product: 21KJ v: ThinkBook 14 G6 ABP
    serial: <superuser required> Chassis: type: 10 v: ThinkBook 14 G6 ABP
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76530 WIN
    serial: <superuser required> part-nu: LENOVO_MT_21KJ_BU_idea_FM_ThinkBook
    14 G6 ABP uuid: <superuser required> UEFI: LENOVO v: MNCN26WW
    date: 12/20/2023
  ID-1: BAT0 charge: 58.3 Wh (98.1%) condition: 59.4/60.0 Wh (99.1%)
    volts: 16.6 min: 15.4 model: BYD2022 L22B4PE0 type: Li-poly serial: <filter>
    status: not charging cycles: 4
  Info: model: AMD Ryzen 7 7730U with Radeon Graphics bits: 64 type: MT MCP
    microcode: 0xA50000F
    L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1391 high: 3889 min/max: 400/4546 scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 2863 2: 400 3: 3889
    4: 400 5: 400 6: 400 7: 2112 8: 400 9: 2001 10: 2026 11: 3634 12: 400
    13: 2134 14: 400 15: 400 16: 400 bogomips: 63874
  Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: DP-1,DP-2,HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:15e7
    class-ID: 0300 temp: 45.0 C
  Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:3 chip-ID: 174f:181d
  Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0
    note: <missing: xdpyinfo/xrandr>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1457 built: 2022 res: 1920x1200
    dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4") diag: 355mm (14")
    ratio: 16:10 modes: max: 1920x1200 min: 640x480
  API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.3-arch1.1
    device-ID: 1002:15e7 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.3-arch1.1 (LLVM
    link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
    snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
    speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.9.8-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
    port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
    driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:b852 class-ID: 0280
  Device-3: ASIX AX88179 Gigabit Ethernet driver: cdc_ncm type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 0b95:1790
  IF: enp5s0f3u1c2 state: up speed: N/A duplex: half mac: <filter>
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:4853
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: not found
    rfk-block: hardware: no software: yes address: see --recommends
  Local Storage: total: 953.87 GiB used: 419.81 GiB (44.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS001TEJ4X112N
    lanes: 4 tech: SSD serial: <filter> fw-rev: 51040C31 temp: 41.9 C
    used: 419.81 GiB (44.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 6.5 MiB (2.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: zram size: 27.25 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: N/A mobo: N/A
  Memory: total: 28 GiB available: 27.25 GiB used: 2.78 GiB (10.2%)
  Processes: 322 Power: uptime: 21m states: freeze,mem,disk suspend: s2idle
    image: 10.89 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 256
  Packages: pm: pacman pkgs: 1306 libs: 404 tools: octopi Compilers:
    clang: 18.1.8 gcc: 14.1.1 Shell: garuda-inxi default: Bash v: 5.2.26
  System install date:     2024-05-24
  Last full system update: 2024-07-10
Try garuda-assistant, restore config.
@SGS thank for you that suggestion, but which checkbox(es) in this screenshot should I tick here? I don’t see a “KDE” or “Themes” one (dunno what “PSD” refers to tho)
Use all :grin:
All config files are in /etc/skel/
You change it, you fix it :blush:
OK done so and re-logged-in but did not solve it at all. Thanks though!
Well c’mon I was only using KDE’s fancy theme-downloading-and-installing features, not editing config files willy-nilly or something. =)
What happens if you create a new user?
Not trying to blame the victim here… but you really need to implement a full backup regimen if you want to be covered when something goes sideways. BTRFS snapshots are in no way a proper replacement for full backups.
