Hello all, I ran in to a few issues with current update. Recently i try to run the open source driver updater for my rx 550 gpu and after reboot only my file manager would come up other wise black screens. I’m seeing some are having challenges with the recent update too. i have my games and all other programs running after using my mother boradvideo out put and snapper, but now i’m nervous to try to update.
this is my garuda-inxi
─edward@ed01 in ~
╰─λ garuda-inxi
Kernel: 6.12.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=65743ce1-7229-4480-ac26-54bec464f9aa rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop System: LENOVO product: 11A9000UUS v: ThinkCentre M75s-1
Mobo: LENOVO model: 3148 v: SDK0J40697 WIN 3305330116396
part-nu: LENOVO_MT_11A9_BU_Think_FM_ThinkCentre M75s-1
uuid: <superuser required> UEFI: LENOVO v: M2CKT38A date: 08/24/2020
Info: model: AMD Ryzen 5 PRO 3400G with Radeon Vega Graphics bits: 64
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2365 min/max: 1400/3700 boost: enabled scaling:
driver: acpi-cpufreq governor: ondemand cores: 1: 2365 2: 2365 3: 2365
4: 2365 5: 2365 6: 2365 7: 2365 8: 2365 bogomips: 59200
Device-1: Advanced Micro Devices [AMD/ATI] Lexa PRO [Radeon
540/540X/550/550X / RX 540X/550/550X] driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 ports: active: DP-1,HDMI-A-1 empty: none
bus-ID: 01:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 62.0 C
Device-2: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel
speed: 8 GT/s lanes: 16 ports: active: none empty: DP-2,DP-3,DP-4
bus-ID: 0e:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 51.0 C
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu,amdgpu d-rect: 3840x1080
display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.7-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 550 / 550 Series
(radeonsi polaris12 LLVM 18.1.8 DRM 3.59 6.12.1-zen1-1-zen)
device-ID: 1002:699f memory: 3.91 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 16 device: 0 type: discrete-gpu name: AMD
Radeon RX 550 / 550 Series (RADV POLARIS12) driver: mesa radv
v: 24.2.7-arch1.1 device-ID: 1002:699f surfaces: xcb,xlib,wayland
device: 1 type: integrated-gpu name: AMD Radeon Vega 11 Graphics (RADV
RAVEN) driver: mesa radv v: 24.2.7-arch1.1 device-ID: 1002:15d8
18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.7-arch1.1 (LLVM 18.1.8)
Device-1: Advanced Micro Devices [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX
550 640SP / 560/560X] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1
chip-ID: 1002:aae0 class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:15de class-ID: 0403
vendor: Lenovo driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x,
bus-ID: 0e:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-4: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 0e:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: Generalplus USB Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-3:4 chip-ID: 1b3f:2008 class-ID: 0300
Device-6: Generic USB SPDIF Adapter
lanes: 1 mode: 1.1 bus-ID: 4-3:3 chip-ID: 4e5b:4032 class-ID: 0300
API: ALSA v: k6.12.1-zen1-1-zen status: kernel-api with: aoss
port: ec00 bus-ID: 0c:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp12s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:3 chip-ID: 0a5c:21e8
Local Storage: total: 1.84 TiB used: 1.64 TiB (89.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 32.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T2531TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 4A0 scheme: GPT
used: 826.27 GiB (88.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 37.13 GiB used: 689.5 MiB (1.8%)
max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 51.8 C mobo: N/A
GPU: device: amdgpu temp: 62.0 C watts: 15.19 device: amdgpu temp: 51.0 C
Memory: total: 40 GiB note: est. available: 37.13 GiB used: 7.38 GiB (19.9%)
Processes: 369 Power: uptime: 1d 6h 22m states: freeze,mem,disk
reboot, suspend, test_resume image: 14.84 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2099 libs: 586
tools: gnome-software,octopi,paru Compilers: clang: 18.1.8 gcc: 14.2.1
Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date: 2024-07-20
Last full system update: 2024-12-04
````Preformatted text`
