Unwanted logout after 5 mins despite power manager saying otherwise
According to these settings I have in my power manager, my computer should stay awake forever if it's plugged in, no matter how long it's been inactive. And yet, it just keeps logging out after 5 minutes of inactivity and I think that's kinda annoying. How do I solve this?
  Kernel: 6.1.13-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=4bc99fd1-6a7e-4096-8fca-ccd010a3944b rw rootflags=subvol=@
    loglevel=3 ibt=off
  Type: Laptop System: Acer product: Aspire A315-56 v: V1.15
  Mobo: IL model: Sleepy_IL v: V1.15 serial: <superuser required>
    UEFI: Insyde v: 1.15 date: 07/13/2020
  ID-1: BAT1 charge: 40.2 Wh (100.0%) condition: 40.2/47.8 Wh (84.1%)
    volts: 12.2 min: 11.2 model: LGC AP18C8K type: Li-ion serial: N/A
    status: full
  Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
    gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xB8
    L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1084 high: 1100 min/max: 400/3400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1100 2: 1038 3: 1100
    4: 1100 bogomips: 9524
  Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
    driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
  Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-7:3
    chip-ID: 0408:a061 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
    loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Monitor-1: eDP-1 model: BOE Display 0x07cb built: 2018 res: 1920x1080
    ratio: 16:9 modes: 1920x1080
    missing.
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
  Sound API: ALSA v: k6.1.13-1-lts running: yes
    speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168
    vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
  IF-ID-1: br-3c4b6f6d3dab state: down mac: <filter>
  IF-ID-2: br-f6b403f2c30d state: down mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  IF-ID-4: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
  Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb
    v: 0.8 bus-ID: 1-10:4 chip-ID: 04ca:3015 class-ID: e001
  Local Storage: total: 238.47 GiB used: 150.04 GiB (62.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
    model: RBUSNS8154P3256GJ1 size: 238.47 GiB block-size: physical: 512 B
    rev: E8FK12.3 temp: 30.9 C scheme: GPT
  ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
    used: 150.04 GiB (63.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 594 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
  ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
  ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.55 GiB used: 3.43 GiB (45.4%)
  System Temperatures: cpu: 61.0 C mobo: N/A
  Processes: 303 Uptime: 1d 23h 57m wakeups: 37 Memory: 7.56 GiB
  used: 3.88 GiB (51.4%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1662
  pm: pacman pkgs: 1656 libs: 409 tools: paru pm: flatpak pkgs: 6 Shell: Bash
  v: 5.1.16 running-in: qterminal inxi: 3.3.25
Garuda (2.6.15-1):
  System install date:     2022-09-11
  Last full system update: 2023-02-25
  Relevant software:       snapper(custom) NetworkManager mkinitcpio
  Failed units:            shadow.service
By this, I assume you mean the lock screen is coming up.
Your pictured settings look fine. However, in addition to the lock screen being deployed in a power management state, it is also deployed with the default screensaver settings.
Open the “Screensaver Preferences”, click the “Lock Screen” tab and switch the toggle that says “Enable Lock Screen”.
