I get this message when the computer starts
sudo dmesg | grep unsupported
[ 1.935404] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
Kernel: 6.1.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=ff14df11-1857-4590-8e3d-20efe22b14f4 rw rootflags=subvol=@
mitigations=off+ quiet quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=3 ibt=off
Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.1 vt: 7
dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: B660M DS3H DDR4 v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F20
date: 10/25/2022
Info: model: 12th Gen Intel Core i7-12700 bits: 64 type: MST AMCP
microcode: 0x26
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 1876 high: 2100 min/max: 800/4800:4900:3600 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 2100 3: 2100
4: 2100 5: 2100 6: 2100 7: 2100 8: 2100 9: 801 10: 2100 11: 2100 12: 2100
13: 1521 14: 2100 15: 2100 16: 2100 17: 799 18: 2100 19: 2100 20: 2100
bogomips: 84480
Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
ports: active: HDMI-A-3 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 compositor: marco v: 1.26.1 driver:
X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Monitor-1: HDMI-A-3 mapped: HDMI-3 model: ASUS VP248 serial: <filter>
built: 2019 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel UHD Graphics 770
(ADL-S GT1) direct-render: Yes
Sound API: ALSA v: k6.1.11-zen1-1-zen running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Local Storage: total: 2.73 TiB used: 62.2 GiB (2.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
lanes: 4 type: SSD serial: <filter> rev: SBJ00101 temp: 28.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
used: 62.2 GiB (6.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 125.58 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 26.0 C mobo: N/A
Processes: 378 Uptime: 17m wakeups: 0 Memory: 125.58 GiB
used: 4.45 GiB (3.5%) Init: systemd v: 252 default: graphical
pkgs: 1608 libs: 384 tools: octopi,pamac,paru Shell: Bash v: 5.1.16
running-in: terminator inxi: 3.3.25
Garuda (2.6.14-1):
System install date: 2023-01-31
Last full system update: 2023-02-12
Grub menu
# GRUB boot loader configuration
GRUB_DEFAULT="0"
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR="Garuda"
GRUB_CMDLINE_LINUX_DEFAULT="quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 ibt=off # Modified by garuda-migrations: ibt=off"
GRUB_CMDLINE_LINUX="mitigations=off+"
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT=10
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
GRUB_THEME="/usr/share/grub/themes/garuda/theme.txt"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
GRUB_DISABLE_OS_PROBER=false
Does that message mean anything or can I ignore it
