Hello,
here is the output of garuda-inxi
Kernel: 5.18.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f9bca527-d148-4e99-8b54-d2f186d91b80 rw [email protected]
Desktop: GNOME v: 42.3.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM
v: 42.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: F2A68HM-H v: x.x serial: N/A
UEFI: American Megatrends v: FB date: 04/22/2015
Info: model: AMD A8-7600 Radeon R7 10 Compute Cores 4C+6G socket: FM2 (P0)
note: check bits: 64 type: MT MCP arch: Steamroller built: 2014
process: GF 28nm family: 0x15 (21) model-id: 0x30 (48) stepping: 1
microcode: 0x6003106
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 256 KiB
desc: d-4x16 KiB; i-2x96 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 1400 min/max: 1400/3100 boost: enabled
base/boost: 3100/3100 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
bogomips: 24755
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: AMD Kaveri [Radeon R7 Graphics] vendor: Gigabyte driver: radeon
v: kernel alternate: amdgpu arch: GCN 2 process: GF/TSMC 16-28nm
built: 2013-17 ports: active: VGA-1 empty: DVI-D-1,HDMI-A-1
bus-ID: 00:01.0 chip-ID: 1002:1313 class-ID: 0300
Device-2: NVIDIA GM206 [GeForce GTX 960] vendor: Micro-Star MSI
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Maxwell process: TSMC 28nm
built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1401 class-ID: 0300
Display: server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: nvidia,radeon
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: radeon
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.00x11.26")
s-diag: 1055mm (41.55")
Monitor-1: HDMI-0 pos: primary,right res: 1920x1080 dpi: 82
Monitor-2: VGA-1-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 96
size: 510x287mm (20.08x11.3") diag: 585mm (23.04") modes: N/A
Device-1: AMD Kaveri HDMI/DP Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:1308 class-ID: 0403
Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-3: NVIDIA GM206 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fba
Sound Server-1: ALSA v: k5.18.12-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.55 running: yes
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus-ID: 2-3:6 chip-ID: 0bda:8179 class-ID: 0000
IF: wlan0 state: down mac: <filter>
Local Storage: total: 2.04 TiB used: 8.6 GiB (0.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM001-1ER164
type: HDD rpm: 7200 serial: <filter> rev: CC25 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SV300S37A240G
type: SSD serial: <filter> rev: BBF0 scheme: GPT
ID-1: / raw-size: 207.81 GiB size: 207.81 GiB (100.00%)
used: 8.6 GiB (4.1%) fs: btrfs block-size: 4096 B dev: /dev/sda3
maj-min: 8:3
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 207.81 GiB size: 207.81 GiB (100.00%)
maj-min: 8:3
ID-4: /var/log raw-size: 207.81 GiB size: 207.81 GiB (100.00%)
maj-min: 8:3
ID-5: /var/tmp raw-size: 207.81 GiB size: 207.81 GiB (100.00%)
maj-min: 8:3
ID-1: swap-1 type: zram size: 14.59 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 10.9 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 54 C fan: 0% device: radeon
temp: 13.0 C
Processes: 221 Uptime: 3m wakeups: 0 Memory: 14.59 GiB
used: 1.18 GiB (8.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1149 lib: 321
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-07-18
Last full system update: 2022-07-18
Is partially upgraded: Yes
Windows dual boot: Yes
So, the problem im currently having is that my internet connection only works for couple of seconds when i restart wifi module with garuda network manager or when i boot into garuda, then it just doesnt work, it says that its connected but nothing works, no data being sent when i ping anything. I dual boot windows and the wifi works fine and its where im currently typing this out. Im using a usb wifi adapter since my computer doesn't have a wifi card.
I have tried a bunch of things and ive been searching all day yesterday on the forums how to fix this issue but nothing fixed it. I can't install any packages or anything else because, well, my wifi isnt working. Here are the things i have tried, ive tried disabling wifi power save and mac address randomization, i tried adding nameserver 1.1.1.1 line to a file, i forgot the name of it tho, didnt work, tried changing dns to 8.8.8.8 and 8.8.4.4, didnt work, i have added garuda to my router mac address filtering, didnt work. And now i am just completely lost, im pretty new to linux so i dont have much knowledge on how to do much stuff. Please help!
