Help would be appreciated ![]()
warning: kde-servicemenus-pdf-encrypt-decrypt: local (1-1.4) is newer than chaotic-aur (1-1)
warning: lib32-mangohud-git: local (0.7.0.rc1.r9.g113912e-1) is newer than chaotic-aur (0.7.0.r59.g9411963-1)
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: jre-openjdk and jre-openjdk-headless are in conflict
inxi
root=UUID=6f7982fa-f801-4a9f-a47e-a2cd8f08ee86 rw rootflags=subvol=@
resume=UUID=4fb2a623-f3ae-4757-9e65-4eb2471f1194 loglevel=3 ibt=off
Type: Desktop Mobo: Gigabyte model: B450 AORUS ELITE
serial: <superuser required> UEFI: American Megatrends LLC. v: F65a
date: 02/09/2023
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000D
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1848 high: 3779 min/max: 400/4673 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3767 2: 3763 3: 400
4: 400 5: 400 6: 3627 7: 400 8: 400 9: 400 10: 3779 11: 400 12: 400
13: 3760 14: 400 15: 3522 16: 3764 bogomips: 121369
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung LC27G5xT
serial: <filter> built: 2021 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:73df memory: 11.72 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.6 chip-ID: 1022:15e3
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
Local Storage: total: 1.56 TiB used: 423.29 GiB (26.4%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 29.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: GOODRAM model: SSDPR-CL100-480-G2
tech: SSD serial: <filter> fw-rev: V4.9 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: PNY model: CS900 240GB SSD
tech: SSD serial: <filter> fw-rev: 0615 scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 38.08 GiB (38.1%)
ID-2: /boot/efi raw-size: 4 GiB size: 3.99 GiB (99.80%)
used: 292 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 811.51 GiB size: 811.51 GiB (100.00%)
used: 385.2 GiB (47.5%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 38.08 GiB (38.1%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 31.21 GiB used: 16.8 MiB (0.1%)
System Temperatures: cpu: 30.5 C mobo: N/A gpu: amdgpu temp: 33.0 C
mem: 32.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 894
Processes: 416 Uptime: 4m wakeups: 0 Memory: total: 32 GiB
available: 31.21 GiB used: 3.91 GiB (12.5%) Init: systemd v: 254
pm: pacman pkgs: 1848 libs: 538 tools: octopi,paru,yay Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2023-06-03
Last full system update: 2023-11-04
