Hi I’m having trouble finishing install of Garuda Wayfire. Specifically, I get unsolvable dependency conflicts when trying to perform the first full upgrade on the system. How do I resolve the conflict and have it not be an issue in the future? Below are the terminal output and garuda-inxi output.
: Synchronizing package databases...
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
:: Replace exa with extra/eza? [Y/n] y
warning: greetd-qtgreet: local (1.0.0-4.1) is newer than chaotic-aur (1.0.0-4)
:: Replace kauth with extra/kauth5? [Y/n] y
:: Replace kconfig with extra/kconfig5? [Y/n] y
:: Replace kcoreaddons with extra/kcoreaddons5? [Y/n] y
:: Replace kitemmodels with extra/kitemmodels5? [Y/n] y
:: Replace knotifications with extra/knotifications5? [Y/n] y
:: Replace kwindowsystem with extra/kwindowsystem5? [Y/n] y
resolving dependencies...
:: python-pyxdg and python-xdg are in conflict. Remove python-xdg? [y/N] y
:: libgedit-amtk and amtk are in conflict. Remove amtk? [y/N] y
y
:: networkmanager-support and networkmanager-fortisslvpn are in conflict. Remove networkmanager-fortisslvpn? [y/N] y
:: installing kvantum (1.0.10-2) breaks dependency 'kvantum-qt5' required by wayfire-desktop
and Garuda-inxi:
```text
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=5e23cba9-94ff-4a15-9277-1d33c1578a64
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
loglevel=3 ibt=off
Desktop: wayfire v: 0.7.5 info: waybar vt: 1 dm: greetd Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20L5S01J00 v: ThinkPad T480 serial: <superuser required>
Chassis: type: 10 serial: <superuser required>
Mobo: LENOVO model: 20L5S01J00 v: SDK0J40709 WIN serial: <superuser required> UEFI: LENOVO
v: N24ET74W (1.49 ) date: 08/15/2023
ID-1: BAT0 charge: 21.9 Wh (100.0%) condition: 21.9/23.9 Wh (91.7%) volts: 12.8 min: 11.4
model: LGC 01AV489 type: Li-poly serial: <filter> status: full cycles: 14
ID-2: BAT1 charge: 64.8 Wh (100.0%) condition: 64.8/62.2 Wh (104.3%) volts: 12.5 min: 11.1
model: SANYO 424 type: Li-ion serial: <filter> status: full cycles: 3
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake gen: core 8 level: v3
note: check built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 0xA (10)
microcode: 0xF4
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1700 high: 2000 min/max: 400/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 2000 3: 2000 4: 2000 5: 2000 6: 800 7: 2000 8: 2000
bogomips: 31999
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel arch: Gen-9.5
process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Bison SunplusIT Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:3
chip-ID: 5986:2113 class-ID: 0e02
Display: wayland server: Xwayland v: 23.1.1 compositor: wayfire v: 0.7.5 driver: gpu: i915
display-ID: 1
Monitor-1: eDP-1 model: BOE Display 0x0791 built: 2017 res: 1920x1080 dpi: 158 gamma: 1.2
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9 modes: 1920x1080
API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480 driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Ethernet I219-V vendor: Lenovo ThinkPad T480 driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd class-ID: 0280
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-7:2
chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 238.47 GiB used: 4.76 GiB (2.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF256G8L size: 238.47 GiB
rev: L14P temp: 22.9 C scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 4.76 GiB (2.0%) fs: btrfs
ID-2:
/boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 4.76 GiB (2.0%) fs: btrfs
ID-4: /var/log raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 4.76 GiB (2.0%) fs: btrfs
ID-5: /var/tmp raw-size: 238.17 GiB size: 238.17 GiB (100.00%) used: 4.76 GiB (2.0%) fs: btrfs
ID-1: swap-1 type: zram size: 7.53 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 39.0 C mobo: N/A
Processes: 249 Uptime: 8m wakeups: 5 Memory: 7.53 GiB used: 2.08 GiB (27.6%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1223
libs: 364 tools: pamac,paru Client: shell wrapper v: 5.1.16-release inxi: 3.3.26
System install date: 2023-10-29
Last full system update: 2023-10-29
Is partially upgraded: Yes
