Hello,
I’ve installed Garuda with the intent to use steam and unreal-engine. I had one minor issue with the install, where I was unable to use Wayland with my nvidia card due to flickering and other errors, so I changed to X11, other than that my system is a standard “KDE Dragonized Gaming Edition”.
The issue that I have is in regards to unreal-engine.
After fiddling about, i decided to go with AUR (en) - unreal-engine-bin
AUR (en) - visual-studio-code-bin
My issue is that the packages install fine, however the modules for the engine don’t seem to be recognised. Unreal engine linux version support is mostly for Ubuntu 22, and I can’t find any archlinux information.
Due to being a new user I can’t upload images.
The errors that I’m getting is an infinite rebuild loop.
I start the c++ project, I then get a window saying that the modules are missing or built with a different engine version, followed by a list of modules (plugins and main game file), and a Question, if I wish to rebuilt them.
After selecting Yes, then unreal-engine uses the Unreal Build Tool to compile everything from source, after a while I get the error “ could not be compiled. Try rebuilding from source manually”, so I proceed to compile from source, in VScode, which compiles succesfully, after opening the project again, it says same error with modules not compiled.
I have run
sudo chmod -R a+rwX /opt/unreal-engine/Engine
sudo chmod -R a+rwX /home/<unreal-engine projects folder>
So all that I can definitely rule out is that read/write permissions are working.
Compilation wise, Unreal Engine fails to rebuild the project files with Unreal Build Tool, files are being created, and they look to me as being the correct files, however it always says that it has been build for a different engine and need a rebuild.
Hope you can help, as I’m stumped, as I can’t figure out how to progress on this issue other than moving to Ubuntu.
Regards
Kernel: 6.9.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=968e428b-61fd-4e31-84b2-b117d8fca139 rw rootflags=subvol=@
quiet resume=UUID=a214afd2-d8f3-4727-96af-7278bfec9680 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop System: Gigabyte product: Z370M DS3H v: N/A
Mobo: Gigabyte model: Z370M DS3H-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F13 date: 08/13/2019
ID-1: hidpp_battery_0 charge: 57% condition: N/A volts: 3.8 min: N/A
Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2134 high: 3804 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 3800 3: 800
4: 3804 5: 3800 6: 800 7: 3800 8: 1815 9: 800 10: 800 11: 3797 12: 800
bogomips: 76799
Device-1: NVIDIA GA102 [GeForce RTX 3090] vendor: Micro-Star MSI
driver: nvidia v: 550.40.63 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
off: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2204
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.02x10.71")
s-diag: 554mm (21.82")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: AOC 2260WG5
serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
max: 1920x1080 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.40.63
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3090/PCIe/SSE2
memory: 23.44 GiB
API: Vulkan v: 1.3.279 layers: 14 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3090 driver: nvidia v: 550.40.63
device-ID: 10de:2204 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
Device-2: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aef
API: ALSA v: k6.9.5-zen1-1-zen status: kernel-api with: aoss
lanes: 1 port: d000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 3.86 TiB used: 385.48 GiB (9.8%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211210WD temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: Ultra II 240GB
tech: SSD serial: <filter> fw-rev: 00RL scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: DT01ACA100
tech: HDD rpm: 7200 serial: <filter> fw-rev: A750 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT2000BX500SSD1
tech: SSD serial: <filter> fw-rev: 061 scheme: GPT
ID-1: / raw-size: 862.2 GiB size: 862.2 GiB (100.00%)
used: 221.65 GiB (25.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 862.2 GiB size: 862.2 GiB (100.00%)
ID-4: /var/log raw-size: 862.2 GiB size: 862.2 GiB (100.00%)
ID-5: /var/tmp raw-size: 862.2 GiB size: 862.2 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.74 GiB used: 37.5 MiB (0.1%)
ID-2: swap-2 type: partition size: 69.02 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 59.0 C mobo: 39.0 C gpu: nvidia temp: 48 C
Memory: total: 64 GiB note: est. available: 62.74 GiB used: 2.79 GiB (4.4%)
Processes: 375 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.05 GiB services: org_kde_powerdevil,
Packages: 2049 pm: pacman pkgs: 2043 libs: 589 tools: octopi,pamac,paru
pm: flatpak pkgs: 6 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-06-05
Last full system update: 2024-06-18
