Unknown Monitor Display Port Nvidia 770
Hey All,
I just installed Garuda a few days ago, hoping to replace windows as my daily driver.
Excited that bambu labs is supported in Linux so that makes me excited.
I’m getting the issue where my monitor shows up as unknown and only gives me 1024x768 as the resolution and that’s a bummer.
I tried doing
sudo nvidia-settings and it gave me a bunch of errors, and I attempted to do sudo pacman -Syu nvidia-dkms to make sure it was installed.
A bit at my wits end for trying to figure this out, even having gone through a bunch of threads, and I feel like I must be missing something simple. Any help would be greatly appreciated.
This is what comes up when I do nvidia-settings
ERROR: NVIDIA driver is not loaded
** (nvidia-settings:19340): WARNING **: 16:01:35.300: Unable to connect to dbus: Error spawning comm
and line “dbus-launch --autolaunch=4e7af29086e7459587537de5e78cc721 --binary-syntax --close-stderr”:
Child process exited with code 1
(nvidia-settings:19340): GLib-GObject-CRITICAL **: 16:01:35.310: g_object_unref: assertion 'G_IS_OBJ
ECT (object)' failed
** (nvidia-settings:19340): CRITICAL **: 16:01:35.311: ctk_powermode_new: assertion '(ctrl_target !=
NULL) && (ctrl_target->h != NULL)' failed
ERROR: nvidia-settings could not find the registry key file or the X server is not accessible. This
file should have been installed along with this driver at
/usr/share/nvidia/nvidia-application-profiles-key-documentation. The application profiles
will continue to work, but values cannot be prepopulated or validated, and will not be
listed in the help text. Please see the README for possible values and descriptions.
(nvidia-settings:19340): GLib-GObject-CRITICAL **: 16:01:35.359: g_object_ref: assertion 'G_IS_OBJEC
T (object)' failed
(nvidia-settings:19340): GLib-GIO-CRITICAL **: 16:01:35.359: g_dbus_connection_register_object: asse
rtion 'G_IS_DBUS_CONNECTION (connection)' failed
T (object)' failed
(nvidia-settings:19340): GLib-GIO-CRITICAL **: 16:01:35.359: g_dbus_connection_get_unique_name: asse
Kernel: 6.9.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=325a065f-f2d6-4cda-98c0-8a49b9d6bb56 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: Gigabyte model: B460M DS3H AC-Y1 v: x.x
UEFI: American Megatrends v: F1 date: 04/13/2020
Info: model: Intel Core i5-10400F bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 3 microcode: 0xFA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4000 min/max: 800/4300 scaling: driver: intel_pstate
governor: powersave cores: 1: 4000 2: 4000 3: 4000 4: 4000 5: 4000 6: 4000
7: 4000 8: 4000 9: 4000 10: 4000 11: 4000 12: 4000 bogomips: 69597
Device-1: NVIDIA GK104 [GeForce GTX 770] vendor: ZOTAC driver: N/A
alternate: nouveau, nvidia_drm, nvidia non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1184
alternate: fbdev,nv,vesa gpu: N/A display-ID: 0
Monitor-1: Unknown-1 res: 1024x768 size: N/A modes: N/A
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast wayland: drv: swrast x11: drv: swrast
API: OpenGL v: 4.5 vendor: mesa v: 24.0.7-arch1.3 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 17.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 15.19 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM
17.0.6) device-ID: 10005:0000 surfaces: xcb,xlib,wayland
Device-1: Intel Comet Lake PCH-V cAVS vendor: Gigabyte driver: snd_hda_intel
chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA GK104 HDMI Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0e0a class-ID: 0403
API: ALSA v: k6.9.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
lanes: 1 port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
IF: wlp8s0 state: up mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:6 chip-ID: 8087:0aa7
Local Storage: total: 5.01 TiB used: 14.23 GiB (0.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000VN006-3CW104
tech: HDD rpm: 5400 serial: <filter> fw-rev: SC60 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: TeamGroup model: T253X2512G
tech: SSD serial: <filter> fw-rev: 7B0 scheme: GPT
model: WD10JMVW-11AJGS4 size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1015 scheme: MBR
used: 14.23 GiB (3.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 15.55 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 32.0 C mobo: 26.0 C
Memory: total: 16 GiB available: 15.55 GiB used: 4.33 GiB (27.8%)
Processes: 297 Power: uptime: 1h 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1883 libs: 545 tools: octopi,paru Compilers:
clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-05-21
Last full system update: 2024-05-21
Try a X11 session instead from the login menu as that only works in an X11 session. (Just click where it says the session type and change it to X11)
The drivers you need for that are the 470 ones; not the one you were trying to install as that is only for more recent cards.
https://aur.archlinux.org/packages/nvidia-470xx-dkms
Thank you =^.^=
I tried moving into an X-11 Session but I just get stuck on a black screen, so I’m going to go try and see if I can install that older nvidia driver and will report back.
Okay, I think I got into X-11 Correctly, but logging out and then switching it and logging back in, instead of making a new session.
Now it’s giving me “None-1” for my monitor.
Here’s teh inxi and the nvidia config
I’m wondering if there’s a power state type thing in my bios for the graphics card that’s messing it up? I’m guess cause of this ** (nvidia-settings:10176): CRITICAL **: 00:33:48.687: ctk_powermode_new: assertion '(ctrl_target !=NULL) && (ctrl_target->h != NULL)' failed
Speed (MHz): avg: 3999 high: 4001 min/max: 800/4300 scaling:
driver: intel_pstate governor: powersave cores: 1: 4000 2: 4000 3: 4000
4: 4000 5: 4000 6: 3999 7: 4001 8: 4000 9: 4000 10: 4000 11: 3999 12: 4000
bogomips: 69597
alternate: nouveau non-free: series: 470.xx+
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.63x7.99")
s-diag: 338mm (13.3")
Monitor-1: Unknown-1 mapped: None-1 res: 1024x768 hz: 60 size: N/A
modes: 1024x768
surfaceless: drv: swrast x11: drv: swrast inactive: wayland
Local Storage: total: 5.01 TiB used: 15.33 GiB (0.3%)
used: 15.33 GiB (3.2%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 33.0 C mobo: 27.0 C
Memory: total: 16 GiB available: 15.55 GiB used: 3.2 GiB (20.6%)
Processes: 348 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1879 libs: 544 tools: octopi,paru Compilers:
Last full system update: 2024-05-23
Failed units:```
```** (nvidia-settings:10176): WARNING **: 00:33:48.676: Unable to connect to dbus: Error spawning command line “dbus-launch --autolaunch=4e7af29086e7459587537de5e78cc721 --binary-syntax --close-stderr”:Child process exited with code 1
(nvidia-settings:10176): GLib-GObject-CRITICAL **: 00:33:48.686: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
(nvidia-settings:10176): GLib-GObject-CRITICAL **: 00:33:48.738: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(nvidia-settings:10176): GLib-GIO-CRITICAL **: 00:33:48.738: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
(nvidia-settings:10176): GLib-GIO-CRITICAL **: 00:33:48.738: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed```
The power thing wasn’t it.
I ended up going and running the system update in Garuda Assistant, and now it’s giving a different error (in X-11)
(nvidia-settings:55317): GLib-GObject-CRITICAL **: 01:08:43.408: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (nvidia-settings:55317): CRITICAL **: 01:08:43.409: ctk_powermode_new: assertion '(ctrl_target !=NULL) && (ctrl_target->h != NULL)' failed
(nvidia-settings:55317): GLib-GObject-CRITICAL **: 01:08:43.458: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(nvidia-settings:55317): GLib-GIO-CRITICAL **: 01:08:43.459: g_dbus_connection_register_object: assertion 'G_IS_DBUS_CONNECTION (connection)' failed
(nvidia-settings:55317): GLib-GObject-CRITICAL **: 01:08:43.459: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(nvidia-settings:55317): GLib-GIO-CRITICAL **: 01:08:43.459: g_dbus_connection_get_unique_name: assertion 'G_IS_DBUS_CONNECTION (connection)' failed```
Okay I’m a numbskull, I didn’t run the nvidia dkmp from the website I was linked. That fixed it. (Though I also switched to HDMI halfway through)
Is the issue completely resolved now?
If so, you can mark the post with the solution.
(icon looks kind of like this: :white_check_mark: )
