Unknown device type nvme0n1
have followed this guide to make my computer faster How to disable CPU mitigations (Danger zone) | Linux and DevOps Stuff !
But when I run sudo update-grub I got this warning
/usr/bin/grub-probe: warning: unknown device type nvme0n1
What does it mean.
  Kernel: 6.1.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=ff14df11-1857-4590-8e3d-20efe22b14f4 rw rootflags=subvol=@
    loglevel=3 ibt=off
  Desktop: MATE v: 1.26.0 info: mate-panel wm: marco v: 1.26.1 vt: 7
    dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: B660M DS3H DDR4 v: x.x
    serial: <superuser required> UEFI: American Megatrends LLC. v: F20
    date: 10/25/2022
  Info: model: 12th Gen Intel Core i7-12700 bits: 64 type: MST AMCP
    microcode: 0x26
  Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
    cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
    L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
  Speed (MHz): avg: 2136 high: 2834 min/max: 800/4800:4900:3600 scaling:
    driver: intel_pstate governor: performance cores: 1: 2834 2: 2100 3: 2100
    4: 2100 5: 2100 6: 2100 7: 2100 8: 2100 9: 2100 10: 2100 11: 2100 12: 2100
    13: 2100 14: 2100 15: 2100 16: 2100 17: 2100 18: 2100 19: 2100 20: 2100
    bogomips: 84480
  Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
    ports: active: HDMI-A-3 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.6 compositor: marco v: 1.26.1 driver:
    X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Monitor-1: HDMI-A-3 mapped: HDMI-3 model: ASUS VP248 serial: <filter>
    built: 2019 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
  API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel UHD Graphics 770
    (ADL-S GT1) direct render: Yes
  Sound API: ALSA v: k6.1.9-zen1-2-zen running: yes
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
  Local Storage: total: 2.73 TiB used: 93.6 GiB (3.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
    lanes: 4 type: SSD serial: <filter> rev: SBJ00101 temp: 29.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
    type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
    used: 93.6 GiB (10.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 125.58 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 27.0 C mobo: N/A
  Processes: 402 Uptime: 34m wakeups: 0 Memory: 125.58 GiB
  used: 4.44 GiB (3.5%) Init: systemd v: 252 default: graphical
  pkgs: 1609 libs: 382 tools: octopi,pamac,paru Shell: Bash v: 5.1.16
  running-in: terminator inxi: 3.3.24
Garuda (2.6.14-1):
  System install date:     2023-01-31
  Last full system update: 2023-02-06
My understanding is this warning has something to do with adding the memtest option to the Grub menu and it is fine to ignore it. If you wish, you can remove the memtest option by getting rid of /etc/grub.d/60_memtest86+.
I get that type of warning even with memtest and some other of grub.d files marked as non-executable.
But it is fine to ignore it, yes.
