Freshly installed Garuda, got my steam library all downloaded and some other games but I’ve noticed that my framerate in some games (baldurs gate 3, minecraft, left 4 dead 2) is uncapped, but when I launch a unity title like Risk of Rain 2, my fps is capped at 60fps even though all my settings in game are set to my monitors refresh rate (240) . I’ve dug through the game’s own config file, and everything in there referring to the refresh rate was 240, Which has left me flabbergasted as I know my configuration has ran Risk of Rain 2 at 240 on other distro’s, Am I missing some kind of dependency? Is it an issue with steam?
Hello and welcome to the forums.
Could we please have your garuda-inxi output as requested by the template?
The entire thing? on a public forum?
just checked a post about that command
root=UUID=f786acd2-1ba6-4cb5-9a52-e19fcc5fbf11 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: MAG X570S TOMAHAWK MAX WIFI (MS-7D54)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.00
date: 07/06/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3711 high: 3834 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3779 2: 3627
3: 3800 4: 3610 5: 3640 6: 3800 7: 3599 8: 3800 9: 3800 10: 3709 11: 3834
12: 3599 13: 3587 14: 3800 15: 3599 16: 3800 bogomips: 121600
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: ASUSTeK driver: nvidia
v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 2d:00.0
chip-ID: 10de:2482 class-ID: 0300
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
s-diag: 1252mm (49.29")
Monitor-1: DP-2 pos: primary,left res: 1920x1080 dpi: 70
size: 698x393mm (27.48x15.47") diag: 801mm (31.54") modes: N/A
Monitor-2: HDMI-1 pos: right res: 1920x1080 hz: 60 dpi: 92
size: 531x298mm (20.91x11.73") diag: 609mm (23.97") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.269 layers: 11 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 545.29.02 device-ID: 10de:2482
surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
bus-ID: 2d:00.1 chip-ID: 10de:228b class-ID: 0403
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:2
chip-ID: 0db0:a073 class-ID: 0300
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 26:00.0
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2725
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:0032
rfk-block: hardware: no software: no address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 4.78 TiB used: 865.6 GiB (17.7%)
fw-rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: ST750LM022 HN-M750MBB
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: MBR
used: 38.46 GiB (8.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.27 GiB used: 46.2 MiB (0.1%)
System Temperatures: cpu: 46.5 C mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 61%
Processes: 362 Uptime: 47m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 4.97 GiB (15.9%) Init: systemd v: 254
pm: pacman pkgs: 1794 libs: 518 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date: 2023-11-13
Last full system update: 2023-11-13
this it?
Are you mirroring displays? What happens if you just use your DP connected monitor?
Okay so, launched Risk of Rain 2 with only my high refresh rate monitor plugged in and that made the game launch at 240, however plugging my other monitor back in made it revert back to 60. How would I resolve this? and thank you for your assistance. Though for some reason launching other titles with both monitors on doesn’t cause an issue. Strange
Looks to be just a Unity game issue in your case.
I’ve noticed Unity games can be a bit fickle when trying to detect the primary display (or its settings). If the game has additional settings to select screens/settings it usually can be remedied.
Oh well, but for my first experience on this forum it was a good one. Thank you!
Hold up, there’s been a development
I’ve now realized that even my operating systems animations (the wobbly tabs and stuff) are also running at 60fps when I have my second monitor plugged in. Turns out its beyond a unity issue
Perhaps its something to do with x11/wayland? Not sure, this is my first arch based distro
If you are using Wayland, Wayland forces Vsync so if your monitor is set at 60 that could be it.
Found the solution: Multi-monitor lag with different refresh rates
run sudo nvidia-settings and make all your displays the same X screen, and enable force full composition pipeline on all of them. This is the same gui where you can find the g-sync toggle if your monitor is g-sync supported or compatible.
