Hi. Me again. How do I uninstall an application on KDE? Im using dragonized btw. I think I’m using the right terminology. I downloaded and installed Xemu xbox emulator from garuda gamer but couldnt get it to work right. now I want to uninstall and reinstall. Please advise. Thanks
Kernel: 6.13.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=36c93a6e-9ff6-4b7e-81b0-3e99d10522fe rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Laptop System: ASUSTeK product: ROG Zephyrus M16 GU603ZM_GU603ZM
Mobo: ASUSTeK model: GU603ZM v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: GU603ZM.310
date: 08/09/2022
ID-1: BAT0 charge: 79.6 Wh (100.0%) condition: 79.6/90.0 Wh (88.4%)
volts: 15.9 min: 15.9 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 19
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
microcode: 0x436
Topology: cpus: 1x dies: 1 clusters: 8 cores: 14 threads: 20 mt: 6 tpc: 2
st: 8 smt: enabled cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32
KiB, 8x64 KiB L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 400 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 107520
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: ASUSTeK
built: 2021-22+ ports: active: none empty: DP-2,DP-3 bus-ID: 0000:00:02.0
chip-ID: 8086:46a6 class-ID: 0380
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 570.124.04 alternate: nouveau,nvidia_drm
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 ports:
active: none off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 0000:01:00.0
chip-ID: 10de:2520 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3 chip-ID: 13d3:56eb
alternate: fbdev,intel,nv,vesa dri: iris gpu: nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 1920x1200 s-dpi: 143 s-size: 341x221mm (13.43x8.70")
s-diag: 406mm (16")
Monitor-1: eDP-1 mapped: DP-0 note: disabled model: BOE Display 0x09cf
built: 2020 res: mode: 1920x1200 hz: 144 scale: 100% (1) dpi: 141 gamma: 1.2
size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10
modes: 1920x1200
drv: nvidia device: 1 drv: iris gbm: drv: iris surfaceless: drv: nvidia x11:
drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 570.124.04
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Laptop
GPU/PCIe/SSE2 memory: 5.86 GiB
API: Vulkan v: 1.4.304 layers: 9 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Laptop GPU driver: N/A device-ID: 10de:2520
surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel Iris Xe
Graphics (ADL GT2) driver: N/A device-ID: 8086:46a6 surfaces: xcb,xlib
device: 2 type: cpu name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: ASUSTeK
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228e
API: ALSA v: k6.13.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.4.0 status: active with: 1: pipewire-pulse
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:8125 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 190.65 GiB (40.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN735 SDBPNHH-512G-1002 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 70626000 temp: 45.9 C scheme: GPT
used: 190.65 GiB (40.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.31 GiB used: 521.5 MiB (3.3%)
max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 51.2 C mobo: N/A gpu: nvidia temp: 60 C
Fan Speeds (rpm): cpu: 1800
Memory: total: 16 GiB note: est. available: 15.31 GiB used: 3.93 GiB (25.7%)
Processes: 440 Power: uptime: 29m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 6.06 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1549 libs: 496
tools: gnome-software,octopi,paru Compilers: gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 4.0.0 running-in: konsole inxi: 3.3.37
System install date: 2025-03-05
Last full system update: 2025-03-10
SGS
12 March 2025 00:17
2
Use paru -R or pacseek in terminal.
found it using pacseek. Now I dont know what to do. I am looking at a screen just like yours except I have a checkmark for chaotic-aur and xemu-git aur. Please advise. Thanks
SGS
12 March 2025 00:26
4
I hate it to wrote, but just press enter if the chaotic-aur text is white in background.
SGS
12 March 2025 00:34
6
https://forum.garudalinux.org/faq
Make the effort to put things in the right place, so that we can spend more time discussing and less cleaning up. So:
Rather than posting “Thank you”, “+1” or “Agreed”, use the like button .
system
Closed
14 March 2025 00:35
7
