how can i uninstall firedragon from garuda since i have decided to use brave
If you already installed brave, I think you could first make it default browser like here.
Then you can
sudo pacman -Rs firedragon
i tried that but its showing
checking dependencies...
:: removing firedragon breaks dependency 'firedragon' required by firedragon-extension-plasma-integration```
its not mentioned in it.
It is, trust me
To remove a package, which is required by another package, without removing the dependent package:
oh yeah thanks a lot. I just checked in the troubleshooting methods
even after doing it fire dragon is still there i used rsu commend btw
oh i tried the rdd command then it worked. did using the rsc command make some issue with the os
