So I figure it's better not to be GPU bound for testing different schedulers and kernels because I would be testing the CPU.
Unigine Heaven Benchmark 4.0
Zen Kernel Zen1
FPS:
215.7
Score:
5435
Min FPS:
27.5
Max FPS:
420.6
System
Platform:
Linux 5.12.10-zen1-1-zen x86_64
CPU model:
AMD Ryzen 5 1600 Six-Core Processor (3693MHz) x12
GPU model:
Unknown GPU (256MB) x1
Settings
Render:
OpenGL
Mode:
1280x720 windowed
Preset
Custom
Quality
Low
Tessellation:
Disabled
PDS Highest Score
FPS:
233.5
Score:
5881
Min FPS:
38.8
Max FPS:
442.2
System
Platform:
Linux 5.12.10-166-tkg-pds x86_64
CPU model:
AMD Ryzen 5 1600 Six-Core Processor (3691MHz) x12
GPU model:
Settings
Render:
OpenGL
Mode:
1280x720 windowed
Preset
Custom
Quality
Low
Tessellation:
Disabled
MuQSS
FPS:
207.7
Score:
5233
Min FPS:
20.5
Max FPS:
414.7
System
Platform:
Linux 5.12.10-166-tkg-muqss x86_64
CPU model:
GPU model:
Settings
Render:
OpenGL
Mode:
1280x720 windowed
Preset
Custom
Quality
Low
Tessellation:
Disabled
BMQ
FPS:
229.7
Score:
5786
Min FPS:
38.6
Max FPS:
428.9
System
Platform:
Linux 5.12.10-166-tkg-bmq x86_64
CPU model:
GPU model:
Settings
Render:
OpenGL
Mode:
1280x720 windowed
Preset
Custom
Quality
Low
Tessellation:
Disabled
Noice! Thanks for sharing
I was using tkg-bmq.... I have switched to linux-cacule.... check that out. I am sure it is faster yet. I am interested in your results. And also the difference between tkg-cacule and linux-cacule. There are people here that have stated the tkg may have cut some things out of the kernel and it has less options available.
Is anyone having memory leaks with Tkg kernels?
CaCULE vs XanMod vs Zen, fullscreen benchmark this time, also I lowered the GPU clock speed to an OC'ed 580 grade to avoid throttling during the benchmark. I did CaCULE in the evening, the others in the morning and I don't remember if I had Spotify and discord open but not sure if that affects performance. Will repeat if not on the margin of error.
FPS:
245.1
Score:
6174
Min FPS:
39.2
Max FPS:
442.9
System
Platform:
Linux 5.12.12-4-cacule-rdb x86_64
CPU model:
AMD Ryzen 5 1600 Six-Core Processor (3566MHz) x12
GPU model:
Settings
Render:
OpenGL
Mode:
1280x720 fullscreen
Preset
Custom
Quality
Low
Tessellation:
Disabled
FPS:
238.1
Score:
5999
Min FPS:
37.5
Max FPS:
437.9
System
Platform:
Linux 5.12.13-170-tkg-cacule x86_64
CPU model:
GPU model:
Settings
Render:
OpenGL
Mode:
1280x720 fullscreen
Preset
Custom
Quality
Low
Tessellation:
Disabled
FPS:
237.3
Score:
5978
Min FPS:
39.6
Max FPS:
442.2
System
Platform:
Linux 5.12.13-1-cacule x86_64
CPU model:
GPU model:
Settings
Render:
OpenGL
Mode:
1280x720 fullscreen
Preset
Custom
Quality
Low
Tessellation:
Disabled
FPS:
227.8
Score:
5737
Min FPS:
38.9
Max FPS:
445.3
System
Platform:
Linux 5.12.13-xanmod1-1 x86_64
CPU model:
GPU model:
Settings
Render:
OpenGL
Mode:
1280x720 fullscreen
Preset
Custom
Quality
Low
Tessellation:
Disabled
FPS:
224.3
Score:
5649
Min FPS:
37.4
Max FPS:
442.9
System
Platform:
Linux 5.12.13-zen1-2-zen x86_64
CPU model:
AMD Ryzen 5 1600 Six-Core Processor (3631MHz) x12
GPU model:
Settings
Render:
OpenGL
Mode:
1280x720 fullscreen
Preset
Custom
Quality
Low
Tessellation:
Disabled
The performance lowered with no app open. Maybe the margin of error of Unigine is higher than I imagined.
FPS:
216.4
Score:
5451
Min FPS:
38.9
Max FPS:
424.5
System
Platform:
CPU model:
AMD Ryzen 5 1600 Six-Core Processor (3723MHz) x12
GPU model:
Settings
Render:
OpenGL
Mode:
1280x720 fullscreen
Preset
Custom
Quality
Low
Tessellation:
Disabled
Hi @binarydepth
Thanks for the benchmarks. I have question about cacule configs.
Was it cacule+rdb or just cacule?
What was the HZ rate?
Thank you
Just cacule, I don't know the configurations since I just installed the packages on the repos. You can see the kernel on "Platform" I copy paste from the Unigine HTML
No worries. I wish if you could try to add CacULE+RDB to the benchmarks please. It should be more performant than regular CacULE.
Thank you so much.
Keep in mind kernels may behave quite different on different machines, so the result might not apply for every device.
Yeah. I guess this post just gives the idea of how to benchmark the scheduler. Has to be CPU bound instead of GPU. All is open for discussion.
Done, added to the top of the list since it's highest score. Next I need to run at least 10 benchmarks and sample the margin of error. New to this so have to sort how I would be more accurate.
This is Fantastic! keep up the work. Very interesting. I kinda figured that Cacule was the fastest!
system
Closed
17 July 2021 17:22
15
