Please delete if this is either already addressed elsewhere or violates a rule or two.
The current method of going through Setup Assistant to check for updates is unintuitive and out of the way. Is it on the devs' roadmap to move to a singular system updater function (either as a separate app or an entry in settings) instead of having to go through Setup Assistant/terminal?
Thank you. You all are doing great work and I love Garuda!
While yes, this is an update method, I was wondering if you all are interested in an update scheme similar to other platforms, such as Android (in Settings > System > Updates), Fedora, etc.
