Ungoogled-chromium suggests adding the OBS (Open Build Service) repo to install the binaries for the package. GitHub - ungoogled-software/ungoogled-chromium-archlinux: Arch Linux packaging for ungoogled-chromium
However, it's also present in the chaotic-aur. Looking how people online don't recommend downloading from the chaotic-aur, I only use it just to update what's included with Garuda Linux like firedragon. All other programs not present in repos, I download them through AUR using paru.
But chromium is one of those big packages which, as I've heard, takes hours on most machines to compile. So pre-compiled binaries is my only option (the AUR package here compiles from source)
Seeing the github page stating OBS repo as official way to get the binaries, how do I make it so that when downloading or updating the ungoogled-chromium package, it is done so through the OBS repo and not chaotic-aur repo?
╰─λ inxi -Faz
System: Kernel: 5.14.15-arch1-g14-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: pm_debug_messages amd_pmc.enable_stb=1 amd_pmc.dyndbg="+p" acpi.dyndbg="file
drivers/acpi/x86/s2idle.c +p" BOOT_IMAGE=/@/boot/vmlinuz-linux-g14
root=UUID=a12edf4b-f91d-4792-a992-2baac1ce3438 rw [email protected] quiet
cryptdevice=UUID=1f19efd7-c4e6-4eaf-accf-83d0acf1403e:luks-1f19efd7-c4e6-4eaf-accf-83d0acf1403e
root=/dev/mapper/luks-1f19efd7-c4e6-4eaf-accf-83d0acf1403e rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3 splash
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401II_GA401II v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GA401II v: 1.0 serial: <filter> UEFI: American Megatrends v: GA401II.219
date: 12/30/2020
Battery: ID-1: BAT0 charge: 58.3 Wh (79.8%) condition: 73.1/76.0 Wh (96.2%) volts: 15.8 min: 15.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes status: Discharging
CPU: Info: 6-Core model: AMD Ryzen 5 4600HS with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600104 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71894
Speed: 2138 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 2138 2: 3805
3: 2996 4: 1744 5: 3464 6: 3692 7: 2753 8: 3595 9: 2572 10: 2942 11: 1819 12: 2223
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 04:00.0
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.15-arch1-g14-1 LLVM 12.0.1) v: 4.6 Mesa 21.2.4
direct render: Yes
Audio: Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.14.15-arch1-g14-1 running: yes
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0 chip-ID: 8086:2723
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 5-4:4 chip-ID: 8087:0029
Drives: Local Storage: total: 953.87 GiB used: 266.32 GiB (27.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB
rev: 004C temp: 47.9 C scheme: GPT
Partition: ID-1: / raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 266.32 GiB (27.9%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-1f19efd7-c4e6-4eaf-accf-83d0acf1403e
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 706 KiB (0.3%) fs: vfat
ID-3: /home raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 266.32 GiB (27.9%) fs: btrfs
ID-4: /var/log raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 266.32 GiB (27.9%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-1f19efd7-c4e6-4eaf-accf-83d0acf1403e
ID-5: /var/tmp raw-size: 953.61 GiB size: 953.61 GiB (100.00%) used: 266.32 GiB (27.9%)
ID-1: swap-1 type: zram size: 15.05 GiB used: 4.5 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 56.4 C mobo: 56.0 C gpu: amdgpu temp: 52.0 C
Fan Speeds (RPM): cpu: 3400
Info: Processes: 341 Uptime: 4h 6m wakeups: 11 Memory: 15.05 GiB used: 3.76 GiB (25.0%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1448 lib: 361
Shell: fish v: 3.3.1 default: Zsh v: 5.8 running-in: konsole inxi: 3.3.08
