Ungoogled-chromium not opening after update
ungoogled-chromium, installed through chaotic-aur not opening anymore.
╰─λ chromium
/usr/lib/chromium/chromium: error while loading shared libraries: libicui18n.so.69: cannot open shared object file: No such file or directory
I don't know how to report packages from chaotic-aur, posted here hoping someone would notify package maintainer or provide solution if this is not related to package itself.
╰─λ inxi -Faz
System:    Kernel: 5.15.2-arch1-g14-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: pm_debug_messages amd_pmc.enable_stb=1 amd_pmc.dyndbg="+p" acpi.dyndbg="file
drivers/acpi/x86/s2idle.c +p" BOOT_IMAGE=/@/boot/vmlinuz-linux-g14
root=UUID=edc8611c-d94e-4567-85f8-02b07c91fda3 rw rootflags=subvol=@ quiet
cryptdevice=UUID=98382a7e-5fd2-4dca-b6e6-6aca242b8ece:luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece
root=/dev/mapper/luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece splash rd.udev.log_priority=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine:   Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA401II_GA401II v: 1.0 serial: <filter>
Mobo: ASUSTeK model: GA401II v: 1.0 serial: <filter> UEFI: American Megatrends v: GA401II.219
date: 12/30/2020
Battery:   ID-1: BAT0 charge: 60.2 Wh (81.4%) condition: 74.0/76.0 Wh (97.4%) volts: 15.8 min: 15.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
Device-1: hidpp_battery_0 model: Logitech G304 Lightspeed Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes status: Discharging
CPU:       Info: 6-Core model: AMD Ryzen 5 4600HS with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600104 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71897
Speed: 2759 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 2759 2: 1603
3: 3915 4: 3643 5: 2996 6: 3553 7: 2588 8: 2657 9: 2767 10: 2855 11: 2202 12: 2270
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics:  Device-1: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 04:00.0
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Monitor-1: eDP res: 1920x1080 hz: 120 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.2-arch1-g14-1 LLVM 13.0.0) v: 4.6 Mesa 21.2.5
direct render: Yes
Audio:     Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.15.2-arch1-g14-1 running: yes
Network:   Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0 chip-ID: 8086:2723
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152 bus-ID: 6-1.4:4
IF: enp4s0f4u1u4 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 5-4:4 chip-ID: 8087:0029
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
Drives:    Local Storage: total: 955.71 GiB used: 67.16 GiB (7.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010T8 size: 953.87 GiB
rev: 004C temp: 31.9 C scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: MassStorageClass size: 1.84 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1539 scheme: MBR
Partition: ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 67.16 GiB (7.0%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-98382a7e-5fd2-4dca-b6e6-6aca242b8ece
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 720 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 67.16 GiB (7.0%) fs: btrfs
ID-4: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 67.16 GiB (7.0%) fs: btrfs
ID-5: /var/tmp raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 67.16 GiB (7.0%) fs: btrfs
ID-1: swap-1 type: zram size: 15.11 GiB used: 6 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): cpu: 2700
Info:      Processes: 327 Uptime: 26m wakeups: 5 Memory: 15.11 GiB used: 2.93 GiB (19.4%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1427 lib: 359
Shell: fish v: 3.3.1 default: Zsh v: 5.8 running-in: konsole inxi: 3.3.08
Updated today and now working again.
I know Chaotic-AUR packages are pre-built, but this post provides some more details as to why this happens:
