Hello.
I have experienced unexpected crash after logging in.
Basically, computer froze and wouldn't open anything.
I used Ctrl+Alt+F4 to reboot the machine but it stuck again during the boot splash screen for more then 10 minutes at which point I held Power button to power off the device.
After that, no issues were encountered.
inzi -Faz output:
System: Kernel: 5.14.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=9d9588e0-3528-417d-969b-f7675645849e rw
rootflags=subvol=@ quiet splash rd.udev.log_priority=3 random.trust_cpu=on vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 resume=UUID=915bc289-3518-43ad-83a3-f27ed97bb979
nvme_core.default_ps_max_latency_us=0 loglevel=3
Desktop: KDE Plasma 5.23.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Dell product: XPS 15 9500 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0W4CRC v: A03 serial: <filter> UEFI: Dell v: 1.9.1 date: 08/11/2021
Battery: ID-1: BAT0 charge: 41.3 Wh (75.4%) condition: 54.8/54.9 Wh (99.9%) volts: 12.0 min: 11.4 model: BYD DELL DVG8M11
type: Li-poly serial: <filter> status: Discharging
CPU: Info: Quad Core model: Intel Core i5-10300H bits: 64 type: MT MCP arch: Comet Lake family: 6 model-id: A5 (165)
stepping: 2 microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 39999
Speed: 900 MHz min/max: 800/2500 MHz Core speeds (MHz): 1: 900 2: 900 3: 897 4: 900 5: 900 6: 898 7: 900 8: 897
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-11:3 chip-ID: 0bda:5510 class-ID: fe01
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.0x12.5") s-diag: 599mm (23.6")
Monitor-1: eDP1 res: 1920x1200 dpi: 143 size: 340x210mm (13.4x8.3") diag: 400mm (15.7")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Drives: Local Storage: total: 476.94 GiB used: 103.73 GiB (21.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX6000LNP size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: V9002s65 temp: 31.9 C scheme: GPT
Partition: ID-1: / raw-size: 459.76 GiB size: 459.76 GiB (100.00%) used: 103.68 GiB (22.6%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 49.4 MiB (19.3%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 459.76 GiB size: 459.76 GiB (100.00%) used: 103.68 GiB (22.6%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 459.76 GiB size: 459.76 GiB (100.00%) used: 103.68 GiB (22.6%) fs: btrfs
ID-5: /var/tmp raw-size: 459.76 GiB size: 459.76 GiB (100.00%) used: 103.68 GiB (22.6%) fs: btrfs
ID-1: swap-1 type: partition size: 16.92 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: swap-2 type: zram size: 15.25 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Info: Processes: 278 Uptime: 10m wakeups: 1289 Memory: 15.25 GiB used: 3.17 GiB (20.8%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1554 lib: 479 Shell: fish v: 3.3.1
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.07
journalctl -b -2 --no-pager --no-hostname -p3 output:
-- Journal begins at Wed 2021-10-13 19:21:09 CEST, ends at Mon 2021-10-18 17:34:08 CEST. --
Oct 18 16:00:49 systemd-modules-load[279]: Failed to find module 'vboxpci'
Oct 18 16:00:50 systemd-udevd[311]: /usr/lib/udev/rules.d/60-libfprint-2-tod1-goodix.rules:2 Unknown group 'plugdev', ignoring
Oct 18 16:00:50 systemd-udevd[311]: /usr/lib/udev/rules.d/60-libfprint-2-tod1-goodix.rules:4 Unknown group 'plugdev', ignoring
Oct 18 16:00:50 systemd-udevd[311]: /usr/lib/udev/rules.d/60-libfprint-2-tod1-goodix.rules:6 Unknown group 'plugdev', ignoring
Oct 18 16:00:50 systemd-udevd[311]: /usr/lib/udev/rules.d/60-libfprint-2-tod1-goodix.rules:8 Unknown group 'plugdev', ignoring
Oct 18 16:00:50 systemd-udevd[323]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
Oct 18 16:00:50 systemd-udevd[345]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
Oct 18 16:00:50 systemd-udevd[323]: vboxnetctl: /usr/lib/udev/rules.d/60-vboxdrv.rules:3 Only network interfaces can be renamed, ignoring NAME="vboxnetctl".
Oct 18 16:00:50 kernel: ioremap error for 0x4febb000-0x4febc000, requested 0x2, got 0x0
Oct 18 16:00:50 systemd-udevd[320]: vboxdrv: /usr/lib/udev/rules.d/60-vboxdrv.rules:1 Only network interfaces can be renamed, ignoring NAME="vboxdrv".
Oct 18 16:00:50 systemd-udevd[317]: vboxnetctl: /usr/lib/udev/rules.d/60-vboxdrv.rules:3 Only network interfaces can be renamed, ignoring NAME="vboxnetctl".
Oct 18 16:00:50 systemd-udevd[329]: vboxdrvu: /usr/lib/udev/rules.d/60-vboxdrv.rules:2 Only network interfaces can be renamed, ignoring NAME="vboxdrvu".
Oct 18 16:00:50 kernel: psmouse serio1: elantech: elantech_send_cmd query 0x02 failed.
Oct 18 16:00:50 kernel: psmouse serio1: elantech: failed to query capabilities.
Oct 18 16:00:51 wpa_supplicant[1715]: nl80211: kernel reports: Attribute failed policy validation
Oct 18 16:00:51 wpa_supplicant[1715]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
Oct 18 16:00:51 wpa_supplicant[1715]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Oct 18 16:01:00 kernel: intel_ish_ipc 0000:00:13.0: [ishtp-ish]: Timed out waiting for FW-initiated reset
Oct 18 16:01:00 kernel: intel_ish_ipc 0000:00:13.0: ISH: hw start failed.
Oct 18 16:01:00 kernel: BUG: unable to handle page fault for address: ffffb14900826034
Oct 18 16:01:00 kernel: #PF: supervisor read access in kernel mode
Oct 18 16:01:00 kernel: #PF: error_code(0x0000) - not-present page
Oct 18 16:01:00 kernel: Oops: 0000 [#1] PREEMPT SMP NOPTI
Oct 18 16:01:00 kernel: CPU: 4 PID: 47 Comm: kworker/4:0 Tainted: G OE 5.14.12-zen1-1-zen #1 aa02fe6d73a54214e828c441e37db3261eb2c4d4
Oct 18 16:01:00 kernel: Hardware name: Dell Inc. XPS 15 9500/0W4CRC, BIOS 1.9.1 08/11/2021
Oct 18 16:01:00 kernel: Workqueue: events fw_reset_work_fn [intel_ish_ipc]
Oct 18 16:01:00 kernel: RIP: 0010:fw_reset_work_fn+0x147/0x280 [intel_ish_ipc]
Oct 18 16:01:00 kernel: Code: 00 00 f3 48 ab 48 8d 4c 24 04 48 89 ef 44 89 6c 24 08 c7 44 24 04 04 0c 04 80 e8 64 fc ff ff 48 8b 85 40 22 00 00 48 83 c0 34 <8b> 00 83 e0 03 83 f8 03 41 0f 95 c4 75 76 48 8b 85 40 22 00 00 48
Oct 18 16:01:00 kernel: RSP: 0018:ffffb1490024fdd0 EFLAGS: 00010282
Oct 18 16:01:00 kernel: RAX: ffffb14900826034 RBX: 000000000000076c RCX: 0000000000000002
Oct 18 16:01:00 kernel: RDX: 0000000000000000 RSI: 0000000000000246 RDI: 0000000000000000
Oct 18 16:01:00 kernel: RBP: ffff969e53a08028 R08: 0000000000000001 R09: 0000000000000000
Oct 18 16:01:00 kernel: R10: 0000000000000000 R11: 0000000000000004 R12: ffff969e53a0a101
Oct 18 16:01:00 kernel: R13: 0000000000000002 R14: ffff96a1cb932900 R15: 0000000000000000
Oct 18 16:01:00 kernel: FS: 0000000000000000(0000) GS:ffff96a1cb900000(0000) knlGS:0000000000000000
Oct 18 16:01:00 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Oct 18 16:01:00 kernel: CR2: ffffb14900826034 CR3: 000000023a610003 CR4: 00000000007706e0
Oct 18 16:01:00 kernel: PKRU: 55555554
Oct 18 16:01:00 kernel: Call Trace:
Oct 18 16:01:00 kernel: process_one_work+0x248/0x430
Oct 18 16:01:00 kernel: worker_thread+0x54/0x4d0
Oct 18 16:01:00 kernel: ? process_one_work+0x430/0x430
Oct 18 16:01:00 kernel: kthread+0x1ae/0x1e0
Oct 18 16:01:00 kernel: ? __kthread_init_worker+0x50/0x50
Oct 18 16:01:00 kernel: ret_from_fork+0x1f/0x30
Oct 18 16:01:00 kernel: Modules linked in: cmac algif_hash algif_skcipher af_alg uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc bnep snd_hda_codec_hdmi qrtr ns snd_sof_pci_intel_cnl snd_sof_intel
_hda_common soundwire_intel btusb btrtl btbcm btintel soundwire_generic_allocation bluetooth soundwire_cadence snd_sof_intel_hda ecdh_generic intel_tcc_cooling snd_sof_pci ecc crc16 snd_sof_xtensa_dsp x86_pkg_temp_thermal intel_powercla
mp snd_sof soundwire_bus joydev coretemp mousedev snd_soc_skl kvm_intel snd_soc_hdac_hda snd_hda_ext_core iTCO_wdt snd_soc_sst_ipc hid_multitouch intel_pmc_bxt snd_soc_sst_dsp 8250_dw snd_soc_acpi_intel_match snd_ctl_led ee1004 snd_soc_
acpi kvm snd_hda_codec_realtek iTCO_vendor_support snd_hda_codec_generic snd_soc_core intel_rapl_msr snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel irqbypass snd_intel_dspcfg crct10dif_pclmul crc32_pclmul snd_intel_sdw_acpi ghash
_clmulni_intel dell_laptop iwlmvm snd_hda_codec aesni_intel
Oct 18 16:01:00 kernel: dell_smm_hwmon crypto_simd mac80211 cryptd rapl intel_cstate libarc4 intel_uncore snd_hda_core snd_hwdep dell_wmi vfat snd_pcm ledtrig_audio iwlwifi fat dell_smbios snd_timer dcdbas dell_wmi_sysman psmouse intel
_spi_pci firmware_attributes_class dell_wmi_descriptor intel_spi intel_wmi_thunderbolt wmi_bmof cfg80211 snd spi_nor processor_thermal_device_pci_legacy soundcore mtd processor_thermal_device i2c_i801 i2c_smbus ucsi_acpi processor_therm
al_rfim processor_thermal_mbox typec_ucsi processor_thermal_rapl intel_lpss_pci thunderbolt typec intel_lpss intel_ish_ipc intel_rapl_common rfkill intel_pch_thermal idma64 intel_ishtp intel_soc_dts_iosf roles i2c_hid_acpi i2c_hid int34
03_thermal int340x_thermal_zone mac_hid intel_hid int3400_thermal acpi_tad sparse_keymap acpi_thermal_rel acpi_pad vboxnetflt(OE) vboxnetadp(OE) vboxdrv(OE) uinput crypto_user fuse zram bpf_preload ip_tables x_tables btrfs rtsx_pci_sdmm
c mmc_core serio_raw atkbd libps2 blake2b_generic libcrc32c
Oct 18 16:01:00 kernel: crc32c_generic xor raid6_pq crc32c_intel rtsx_pci xhci_pci xhci_pci_renesas i8042 serio nouveau drm_ttm_helper mxm_wmi wmi intel_agp i915 i2c_algo_bit ttm video drm_kms_helper syscopyarea sysfillrect sysimgblt f
b_sys_fops cec drm intel_gtt agpgart
Oct 18 16:04:36 systemd[1]: Failed to start RealtimeKit Scheduling Policy Service.
Feel free to ignore errors until 16:01:00 since I think those are unrelated and I plan on creating different post if I don't manage to solve those.
If anything else is needed I comment below and I will try to provide it.
