I tried searching the forums and the googles for how to fix this but I wasn’t able to find anything.
I’m trying to run the update assistant and I am getting the following message:
removing appstream-qt breaks dependency 'appstream-qt' required by apper
root=UUID=435716c2-fab0-48db-a396-d7cd68ec4368 rw rootflags=subvol=@
resume=UUID=291ca7d0-2be9-4ea8-ae6a-b2e2b7e10d4d loglevel=3 ibt=off
Type: Desktop System: NZXT product: X570 AORUS MASTER v: -CF
Mobo: Gigabyte model: X570 AORUS MASTER v: x.x
serial: <superuser required> BIOS: American Megatrends v: F32
date: 01/18/2021
ID-1: hidpp_battery_1 charge: 79% condition: N/A volts: 4.0 min: N/A
serial: <filter> status: N/A
Device-1: hidpp_battery_2 model: Logitech Wireless Keyboard K270
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: N/A
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2488 high: 3601 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3601 2: 2489
3: 2877 4: 2281 5: 2198 6: 2879 7: 3201 8: 2879 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 2199 15: 2200 16: 2200 17: 3596 18: 2303 19: 2880
20: 2878 21: 2418 22: 2200 23: 2879 24: 2879 25: 2200 26: 2200 27: 2200
28: 2200 29: 2200 30: 2199 31: 2196 32: 2199 bogomips: 217621
Device-1: NVIDIA GA102 [GeForce RTX 3080 Ti] driver: nvidia v: 545.29.02
2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.0
chip-ID: 10de:2208 class-ID: 0300
Screen-1: 0 s-res: 4480x1080 s-dpi: 101 s-size: 1128x272mm (44.41x10.71")
s-diag: 1160mm (45.68")
Monitor-1: DP-0 pos: primary,right res: 2560x1080 dpi: 81
size: 798x334mm (31.42x13.15") diag: 865mm (34.06") modes: N/A
Monitor-2: HDMI-0 pos: left res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.74x10.55") diag: 546mm (21.51") modes: N/A
Monitor-3: None-1-1 size-res: N/A modes: N/A
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2
memory: 11.72 GiB
API: Vulkan v: 1.3.269 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3080 Ti driver: nvidia v: 545.29.02 device-ID: 10de:2208
surfaces: xcb,xlib
Device-1: NVIDIA GA102 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:1aef
Device-3: Audio-Technica AT2020USB+
lanes: 1 mode: 1.1 bus-ID: 3-6.3:7 chip-ID: 0909:001c class-ID: 0300
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0
Device-3: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:6 chip-ID: 8087:0029
Report: btmgmt ID: hci1 rfk-id: 2 state: down bt-service: enabled,running
Device-2: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:2 chip-ID: 0b05:190e
Report: ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
Supported mdraid levels: raid6 raid5 raid4
Device-1: md0 maj-min: 9:0 type: mdraid level: raid-6 status: active
Info: report: 4/4 UUUU blocks: 7813772288 chunk-size: 512k
super-blocks: 1.2 algorithm: 2
Components: Online:
0: sdb maj-min: 8:16 size: 3.64 TiB
1: sdc maj-min: 8:32 size: 3.64 TiB
2: sdd maj-min: 8:48 size: 3.64 TiB
3: sde maj-min: 8:64 size: 3.64 TiB
Local Storage: total: raw: 16.37 TiB usable: 9.1 TiB used: 1.23 TiB (13.6%)
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 211210WD temp: 44.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
model: WD40EFAX-68JH4N1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 5400 serial: <filter>
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
ID-6: /dev/sde maj-min: 8:64 vendor: Seagate model: ST4000NE001-3CR101
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: HDD rpm: 7200
ID-1: / raw-size: 897.09 GiB size: 897.09 GiB (100.00%)
used: 836.95 GiB (93.3%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 897.09 GiB size: 897.09 GiB (100.00%)
ID-3: /var/log raw-size: 897.09 GiB size: 897.09 GiB (100.00%)
ID-4: /var/tmp raw-size: 897.09 GiB size: 897.09 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.42 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 125.74 GiB used: 34.8 MiB (0.0%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32
System Temperatures: cpu: 57.1 C mobo: 38.0 C gpu: nvidia temp: 39 C
Fan Speeds (rpm): fan-1: 1196 fan-2: 0 fan-3: 0 gpu: nvidia fan: 35%
Power: 12v: N/A 5v: N/A 3.3v: 3.36 vbat: 3.29
Processes: 601 Uptime: 6h 25m wakeups: 0 Memory: total: 128 GiB note: est.
available: 125.74 GiB used: 23 GiB (18.3%) Init: systemd v: 254
Packages: 1714 pm: pacman pkgs: 1662 libs: 476 tools: octopi,paru,trizen,yay
pm: flatpak pkgs: 52 Shell: fish v: 3.6.1 default: Bash v: 5.2.15
Garuda (2.6.18-1):
System install date: 2022-09-08
Last full system update: 2023-11-21
Failed units: barrierapp.service connectiscsi.service mdmonitor.service vmware-networks-server.service vmware.service
