Unable to switch to Plasma x11 after a fresh install
Hello. I would like som helpt with that. I’m running Garuda Dr460nized Gaming Edition with KDE Plasma 6.5.2 and I have lost the ability to switch to Plasma X11 after I had to reinstall my computer. The little gear that allows me to switch to X11 isn´t available in this new version of dr460nized gaming edition.
Do you know how I can fix that?
Please do not hijack topics that have already been resolved and are unrelated to your issue. I have moved your post to a new thread. Please post your garuda-inxi here. From the topic template that you were unable to read:
Topic template
:warning: Missing information requested in the template may result in not receiving assistance :warning:
Issue still unresolved? Then:
  • ONE issue per topic.
  • Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</>), or put three tildes (~) above and below the text
Install plasma-x11-session:
sudo pacman -S plasma-x11-session
Then reboot and select “Plasma (x11)” as your desktop session on the login screen.
Hi.
Thanks.
Sorry. I will try to do that in the future. What is garuda-inxi?
Thanks for the help.
Open a terminal, type in
press enter, then copy the output and paste it here using a code block.
The forum is full of them, please, search first then ask.
The template you’re missing because you posted in the wrong thread.
