I have posted my inxi and i have tried garuda-update twice. how do you use garuda-inxi when it's not recognized as a command?
β― sudo garuda-inxi ββ―
[sudo] password for sevenday4:
sudo: garuda-inxi: command not found
I have tried garuda-assistant as well as ```
sudo pacman -Syu --overwrite '*'
β― sudo pacman -Syu --overwrite '*' ββ―
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
blackarch is up to date
warning: bytecode-viewer: local (1:2.9.22-1) is newer than chaotic-aur (2.10.16-1)
warning: dislocker: local (553.1053356-2) is newer than chaotic-aur (0.7.3-2)
warning: garuda-settings-manager-git: local (1.0.0.r1.g15c4106-3) is newer than chaotic-aur (1.0.0.r1.g15c4106-1)
warning: gpredict: local (1619.a0a5636-1) is newer than chaotic-aur (2.2.1-2)
warning: gsocket: local (450.e4d734a-1) is newer than community (1.4.33-1)
warning: nbtscan: local (36.8ab6a70-1) is newer than community (1.7.2-1)
warning: plumber: local (18.3f1be68-3) is newer than community (1.0.1-1)
warning: python-crc16: local (0.1.1-7) is newer than blackarch (0.1.1-3)
warning: python-pyside: local (1.2.4-13) is newer than chaotic-aur (1.2.4-10)
warning: python-pyside-common: local (1.2.4-13) is newer than chaotic-aur (1.2.4-10)
warning: python-shiboken: local (1.2.4-9) is newer than chaotic-aur (1.2.4-8)
warning: python-tld: local (0.12.6-2) is newer than community (0.12.6-1)
warning: python2-pyside: local (1.2.4-13) is newer than chaotic-aur (1.2.4-10)
warning: python2-shiboken: local (1.2.4-9) is newer than chaotic-aur (1.2.4-8)
warning: python2-stringcase: local (1.2.0-4) is newer than chaotic-aur (1.2.0-1)
warning: syft: local (814.5e5312c-1) is newer than community (0.35.1-1)
resolving dependencies...
:: installing python-httpx (0.22.0-1) breaks dependency 'python-httpx<0.22' required by python-httpx-socks
This is a real head scratcher. I usually can figure things like this out, but...
β― pacman -Ss python-httpx ββ―
community/python-httpx 0.22.0-1 [installed: 0.21.3-1]
A next generation HTTP client for Python
chaotic-aur/python-httpx-socks 1:0.7.2-2 [installed]
HTTP/SOCKS-proxy transports for httpx
blackarch/python-httpx-socks 0.7.2-1 [installed: 1:0.7.2-2]
Proxy (HTTP, SOCKS) transports for httpx.
I have also tried
sudo pacman -S python-httpx-socks && sudo pacman -Syu twice rebooting ater each try.
sudo pacman -S python-httpx-socks && sudo pacman -Syu ββ―
warning: python-httpx-socks-1:0.7.2-2 is up to date -- reinstalling
Packages (1) python-httpx-socks-1:0.7.2-2
Total Installed Size: 0.05 MiB
Net Upgrade Size: 0.00 MiB
(1/1) checking keys in keyring [----------------------] 100%
(1/1) checking package integrity [----------------------] 100%
(1/1) loading package files [----------------------] 100%
(1/1) checking for file conflicts [----------------------] 100%
(1/1) checking available disk space [----------------------] 100%
(1/1) Creating Timeshift snapshot before upgrade...
Using system disk as snapshot device for creating snapshots in BTRFS mode
Mounted '/dev/sdb3' at '/run/timeshift/backup'
Creating new backup...(BTRFS)
Saving to device: /dev/sdb3, mounted at path: /run/timeshift/backup
Created directory: /run/timeshift/backup/timeshift-btrfs/snapshots/2022-01-27_12-59-20
Created subvolume snapshot: /run/timeshift/backup/timeshift-btrfs/snapshots/2022-01-27_12-59-20/@
Created control file: /run/timeshift/backup/timeshift-btrfs/snapshots/2022-01-27_12-59-20/info.json
BTRFS Snapshot saved successfully (5s)
Tagged snapshot '2022-01-27_12-59-20': ondemand
** (process:47611): CRITICAL **: 12:59:26.733: gee_abstract_collection_get_size: assertion 'self != NULL' failed
(1/1) reinstalling python-httpx-socks [----------------------] 100%
(1/5) Arming ConditionNeedsUpdate...
(2/5) Foreign/AUR package notification
cups-ocr 0.1.2-4
jre7-openjdk 7.u261_2.6.22-1
jre7-openjdk-headless 7.u261_2.6.22-1
nerd-fonts-hack 2.1.0-4
notepadqq-git 2.0.0.beta.r12.gd8000f25-1
pacaur 4.8.6-1
python-selenium 3.141.0-4
(3/5) Orphaned package notification...
=> No orphans found.
(4/5) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/nsswitch.conf.pacnew
/etc/default/grub.pacnew
/etc/default/grub-btrfs/config.pacnew
/etc/pamac.conf.pacnew
/etc/pacman.conf.pacnew
/etc/paru.conf.pacnew
/etc/systemd/system.conf.pacnew
/etc/systemd/user.conf.pacnew
Please check and merge
(5/5) Syncing all file systems...
core is up to date
extra is up to date
community 6.0 MiB 1193 KiB/s 00:05 [----------------------] 100%
I had to uninstall rapidscan, sniper, and wapiti in order to install python-httpx-socks then reinstall them after updating. Wonder why blackarch version of python-httpx-socks would not update, quite strange.
