BootCurrent: 0004
Timeout: 1 seconds
BootOrder: 0004,0002,0000,0001,0003,0005
Boot0000* ubuntu HD(1,GPT,e6d90f16-99bd-4a3f-9852-4407caa38f4c,0x800,0x100000)/File(\EFI\UBUNTU\SHIMX64.EFI)
Boot0001* Windows Boot Manager HD(1,GPT,e6d90f16-99bd-4a3f-9852-4407caa38f4c,0x800,0x100000)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)0000424f
Boot0002* Garuda HD(1,GPT,b7f3a48f-27c6-f744-9da3-23299a3f4485,0x1000,0x96000)/File(\EFI\GARUDA\GRUBX64.EFI)
Boot0003* UEFI OS HD(1,GPT,b7f3a48f-27c6-f744-9da3-23299a3f4485,0x1000,0x96000)/File(\EFI\BOOT\BOOTX64.EFI)0000424f
Boot0004* UEFI: Sandisk USB Ultra 1100 PciRoot(0x0)/Pci(0x14,0x0)/USB(2,0)/CDROM(1,0x806b58,0x8000)0000424f
Boot0005* UEFI: Sandisk USB Ultra 1100, Partition 2 PciRoot(0x0)/Pci(0x14,0x0)/USB(2,0)/HD(2,MBR,0x0,0x806b58,0x2000)0000424f
efi folder doesnt exist in the boot directory. Idk why is that. I think theres something wrong with the path we are giving to delete microsoft and ubuntu
rm: cannot remove '/boot/efi/EFI/MICROSOFT': No such file or directory
Somebody, please help
Please provide from your live USB the output of the following commands:
sudo fdisk -l
sudo parted -l | grep -iE "^Disk /|esp" | grep -B1 esp
Did you mount the EFI partition while in the live media?
Which manufacturer's system do you have?
It's not all that tough, actually; it's probably because you are doing it for the first time.
Do you still have Ubuntu and Windows installed?
Please, post terminal outputs as text like your garuda-inxi.
Also, please post everytime your input too
sudo rm -r /boot/efi/EFI/MICROSOFT
Same for the other commands you got.
My efibootmgr look so
\EFI\garuda\grubx64.efi
\EFI\Microsoft\Boot\bootmgfw.efi
I don’t know why I also have lowercase letters?
Do in terminal
su
ls -la /boot/efi/EFI
drwx------ 2 root root 4096 4. Feb 2021 Boot
drwx------ 2 root root 4096 24. Jul 2021 Garuda
drwx------ 4 root root 4096 4. Feb 2021 Microsoft
You cannot see it because you are in the live environment--the EFI partition is not mounted.
An easy way to get set up would be click on the chroot tool and identity the Garuda installation. Otherwise the EFI partition needs to be explicitly mounted.
Guys, thanks for all your help. I changed the bios setting and it worked. It was that simple. LOL.
