After invoking sudo pacman -S printer-support then sudo systemctl enable cups
and sudo systemctl start cups I am unable to print via qpdfview, Firefox or Brave. What is my next move?
╰─λ garuda-inxi
Kernel: 6.6.22-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c6251b33-c81f-43de-b1fc-a36db6234086 rw rootflags=subvol=@
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
with: xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Type: Desktop Mobo: Gigabyte model: B450M DS3H V2 v: x.x
Megatrends LLC. v: F62 date: 01/27/2022
Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
microcode: 0x8108109
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1400 min/max: 1400/3600 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1400 3: 1400
4: 1400 bogomips: 28756
vendor: Gigabyte driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: HDMI-A-1 empty: DVI-D-1 bus-ID: 06:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 37.0 C
Device-2: Microdia Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 0c45:64ab
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.11 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Screen-1: 0 s-res: 1152x864 s-dpi: 96 s-size: 305x229mm (12.01x9.02")
s-diag: 381mm (15.02")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Acer 0x0019 serial: <filter>
built: 2009 res: 1152x864 hz: 75 dpi: 7 gamma: 1.2
size: 4095x4095mm (161.22x161.22") diag: 434mm (17.1") ratio: 5:4, 4:3
modes: max: 720x480 min: 720x400
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 24.0.3-arch1.2
device-ID: 1002:15d8 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.2 (LLVM
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.6.22-1-lts status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 114.87 GiB (6.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500325AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: BSM1 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1
tech: SSD serial: <filter> fw-rev: 046 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46 scheme: GPT
ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
used: 12.29 GiB (2.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.71 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.9 C mobo: 28.0 C gpu: amdgpu temp: 36.0 C
Memory: total: 6 GiB available: 5.71 GiB used: 1.68 GiB (29.5%)
Processes: 269 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.27 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1418 libs: 427 tools: paru pm: flatpak pkgs: 0
Compilers: gcc: 13.2.1 Shell: garuda-inxi default: Bash v: 5.2.26
running-in: xfce4-terminal inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-02-04
Last full system update: 2024-03-26
╭─ion@SMA in ~ took 7s
