Unable to mount NTFS drive on Garuda
Good morning,
sudo garuda-inxi
[sudo] password for john:
Kernel: 6.10.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=4888c917-7368-4db7-9b43-4b9817ee22d8 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7B51 v: 1.0 serial: N/A
Mobo: Micro-Star model: MPG Z390 GAMING PLUS (MS-7B51) v: 1.0
serial: <filter> uuid: 091c8cd9-a420-4d1c-ac2b-2cf05dd22580
UEFI: American Megatrends v: 1.E1 date: 11/17/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540e
Info: model: Intel Core i5-9600K socket: LGA1151 (U3E1) note: check bits: 64
type: MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xD (13)
microcode: 0x100
desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4600 base/boost: 3700/8300 scaling:
driver: intel_pstate governor: powersave volts: 1.1 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 bogomips: 44398
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 555.58.02
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: none off: DP-3 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
Device-2: Realtek EKACOM-K20E driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 0bda:5696
Display: unspecified server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x392mm (27.64x15.43")
s-diag: 804mm (31.65")
Monitor-1: DP-3 mapped: DP-4 note: disabled model: Samsung U32R59x
serial: <filter> built: 2022 res: 3840x2160 hz: 60 dpi: 140 gamma: 1.2
max: 3840x2160 min: 640x480
inactive: wayland,device-1
memory: 11.72 GiB
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3060 driver: nvidia v: 555.58.02
device-ID: 10de:2504 surfaces: xcb,xlib
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
Device-3: Realtek EKACOM-K20E driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.10.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.2 status: n/a (root, process) with:
Device-2: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.1
Local Storage: total: 16.94 TiB used: 290.22 GiB (1.7%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Western Digital
model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 211210WD temp: 39.9 C scheme: GPT
SMART: yes health: PASSED on: 344d 20h cycles: 1,362
read-units: 24,285,354 [12.4 TB] written-units: 31,076,052 [15.9 TB]
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 111110WD temp: 42.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 71d 10h cycles: 1,778
read-units: 24,032,140 [12.3 TB] written-units: 25,365,205 [12.9 TB]
ID-3: /dev/nvme2n1 maj-min: 259:9 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
SMART: yes health: PASSED on: 38 hrs cycles: 149
read-units: 122,220 [62.5 GB] written-units: 589,274 [301 GB]
ID-4: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD101FZBX-00ATAA0 size: 9.1 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: 1A01 temp: 50 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 27d 8h cycles: 123 Old-Age:
UDMA CRC errors: 99
ID-5: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD30EFRX-68EUZN0 family: Red size: 2.73 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 0A82 temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 84d 19h cycles: 2588
ID-6: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD20PURZ-85GU6Y0 family: Purple (Pro) size: 1.82 TiB block-size:
rpm: 5400 serial: <filter> fw-rev: 0A80 temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 349d 2h cycles: 1466
ID-7: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WDS100T2B0A-00SM50 family: WD Blue / Red / Green SSDs
size: 931.51 GiB block-size: physical: 512 B logical: 512 B sata: 3.3
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 00WD temp: 26 C
SMART: yes state: enabled health: PASSED on: 1y 113d 1h cycles: 1924
Old-Age: UDMA CRC errors: 79
ID-8: /dev/sdf maj-min: 8:80 vendor: NorelSys model: 1081CS1
size: 119.08 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
scheme: MBR
used: 290.22 GiB (62.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:8
used: 588 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:7
maj-min: 259:8
maj-min: 259:8
maj-min: 259:8
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 6 dev: /dev/zram0
System Temperatures: cpu: 37.0 C pch: 68.0 C mobo: N/A gpu: nvidia
temp: 44 C
Memory: total: 32 GiB available: 31.28 GiB used: 4.69 GiB (15.0%)
Processes: 322 Power: uptime: 16m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.45 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1744 libs: 517 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.32
System install date:     2024-08-19
Last full system update: 2024-08-20
Relevant software:       snapper(custom) NetworkManager dracut nvidia-dkms
Windows dual boot:       Yes
The drive mounts normally on Windows and Mint with no issue.
I have been able to mount it using
sudo mount -t ntfs-3g /dev/sda2 /mnt/ntfs-broken
But this of course is not a long term solution.
I have ran:
sudo ntfsfix /dev/sda2
Which seemed to complete successfully
Mounting volume... OK
Processing of $MFT and $MFTMirr completed successfully.
Checking the alternate boot sector... OK
NTFS volume version is 3.1.
Going to un-mark the bad clusters ($BadClus)... No bad clusters...OK
NTFS partition /dev/sda2 was processed successfully.
And I’m all out of ideas.
I began running chkdsk repair on windows, but it will take 10 hours for this 10TB drive, and in any case as said it is working normally on both Windows and Mint so think there must be some simpler solution.
Thanks
Missed out a key bit of info, when attempting to mount, it shows:
An error occurred while accessing ‘drive’ the system responded: the requested operation has failed. Error mounting /dev/sda2 at /run/media/…etc. Wrong fs type, bad option, bad superblock on /dev/sda2 missing codepage or helper program, or other error.
We highly discourage the use of NTFS partitions in Linux. Data get corrupted so often! Just search in the forum for NTFS or even better ntfsfix.
Usually you can fix the problem with that tool.
Sometimes you have to do it from Windows.
But sometimes nothing will work and you’ll have to use your backups (hopefully…).
I’m not so deep into the technical details, but this is just the way it is.
And that’s another reason for not supporting dual boot.
Do yourself a favour: recover again your data with ntfsfix if you can (edit: I see in this case you need chkdsk /f, and reboot twice IIRC), backup that partition and format it as e.g. ext4…
BTW, have done ntfsfix /dev/sda2 -b -d and it fixed the problem for me.
We always mark here the solution and not the implementation. :slight_smile:
He did not present a solution. Maybe some vague, regurgitated things he read on other posts without clearly reading mine.
Unless of course, you mean he ironically presented a solution by letting people know that they are on their own, and you need to find your own way out of the mess.
You’d better search and read the forum as we’ll, since there are at least 28 solutions related to ntfsfix. That’s why I was not ironical at all.
https://forum.garudalinux.org/search?context=topic&context_id=38816&q=ntfsfix%20%20status%3Asolved%20order%3Alatest&skip_context=true
This is not true. I saw you already used ntfsfix successfully, but I assumed it was not working, or the problem persisted afterwards.
I don’t care anything about the solution, of course, but I mainly wanted to point out that your response was extremely disrespectful.
