Hello, I am a newbie trying to install on a partition to dual boot with windows. Fairly certain my issue is related to having BIOS SATA mode set to VMD, which I'd like to keep as that how it was set when I installed windows.
I did review this post, but I don't know how to "regenerate the mkinit file in chroot environment with the vmd modules being forced" in my case as I can't get Garuda to boot (hangs).
Welcome to the forums.
VMD would only come into play after an install, your problem is on boot from your USB if I'm correct.
Since you get to the menu, usually then it's graphics related.
Maybe others can help you as graphics isn't my strong point.
I agree.
If you cannot start the USB, try to e.g. recreate it with balena Etcher or Ventoy.
If you installed, but the installed system doesn’t boot, check here https://wiki.archlinux.org/title/Dell_XPS_13_(9310)#Bootloader_fails_to_find_boot_disk
If that works, but you necessarily need vmd (sometimes needed for dual booting), there are several posts about it. E g.
If you don’t know how to chroot, there’s a tool in the live USB or a tutorial in the forum.
