Hello everyone. I recently installed Garuda LXQt Kwin and found that there are no keyboard shortcuts set for closing, minimizing and maximizing windows or moving windows around workspaces, per the Shortcut Keys
app that I can find in the menu. When I create one, I can set the keystroke combination but I cannot select the action (close window, maximize window, etc), because I don't know what the command for that would be, and I couldn't find a list of commands for LXQt/Kwin I can use for the keyboard shortcuts.
Can an experienced user provide me with a list of commands or an insight on where should I look for them? Or maybe the app I am talking about is not the one I should be using? Thank you
By the way, I just found out Alt+F4 (not the shortcut I would like) closes the window but is not listed in the Shortcut Keys
app, so I guess there must be another configurator around there but I am unable to find it.
Kernel: 5.16.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=c25e5f86-6783-4d6e-b5a0-7d4e06c7f3a8 rw rootflags=subvol=@
Desktop: LXQt 1.0.0 tk: Qt 5.15.3 info: cairo-dock, lxqt-panel
Type: Laptop System: BANGHO product: MAX L4 v: MAX L4
serial: <superuser required> Chassis: type: 10 v: N/
Mobo: BANGHO model: MAX L4 serial: <superuser required> UEFI: INSYDE
v: 1.07.07RPA2 date: 11/27/2020
ID-1: BAT0 charge: 34.0 Wh (87.9%) condition: 38.7/36.2 Wh (107.0%)
volts: 12.1 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter>
status: Discharging
Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus
family: 6 model-id: 0x7A (122) stepping: 8 microcode: 0x1C
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1515 high: 1523 min/max: 800/2800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1508 2: 1523
bogomips: 4377
Device-1: Intel GeminiLake [UHD Graphics 600] vendor: CLEVO/KAPOK
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300
Device-2: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-7:5
chip-ID: 5986:9102 class-ID: 0e02
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
s-diag: 414mm (16.3")
Monitor-1: eDP1 mapped: eDP-1 model: Chi Mei Innolux built: 2016
res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9") ratio: 16:9 modes: 1366x768
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_apl bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0403
Sound Server-1: ALSA v: k5.16.13-zen1-1-zen running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 02:00.0
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-3:2 chip-ID: 13d3:3533 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 111.79 GiB used: 8.3 GiB (7.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400M8120G
type: SSD serial: <filter> rev: 62B3 scheme: MBR
ID-1: / raw-size: 39.06 GiB size: 39.06 GiB (100.00%)
used: 8.17 GiB (20.9%) fs: btrfs dev: /dev/sda7 maj-min: 8:7
ID-2: /boot raw-size: 256 MiB size: 252 MiB (98.46%)
used: 135.3 MiB (53.7%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 296 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-4: /home raw-size: 39.06 GiB size: 39.06 GiB (100.00%)
ID-5: /var/log raw-size: 39.06 GiB size: 39.06 GiB (100.00%)
ID-6: /var/tmp raw-size: 39.06 GiB size: 39.06 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.33 GiB used: 147 MiB (4.3%) priority: 100
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 209 Uptime: 42m wakeups: 1 Memory: 3.34 GiB
used: 2.32 GiB (69.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1139 lib: 291 Shell: Bash v: 5.1.16
running-in: qterminal inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-03-10
Last full system update: 2022-03-10
