Sorry for the missing garuda-inxi output:
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=cd382bd2-defe-4b7b-b2b4-f47cbe7d9e7d rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: LENOVO product: 20HES2BD0J v: ThinkPad T470
Mobo: LENOVO model: 20HES2BD0J v: SDK0J40697 WIN serial: <filter>
part-nu: LENOVO_MT_20HE_BU_Think_FM_ThinkPad T470
uuid: 766904cc-2148-11b2-a85c-f88b6f6149cf UEFI-[Legacy]: LENOVO
v: N1QETA1W (1.76 ) date: 11/06/2023
ID-1: BAT0 charge: 20.0 Wh (100.0%) condition: 20.0/24.0 Wh (83.5%)
volts: 12.7 min: 11.5 model: SMP 01AV421 type: Li-poly serial: <filter>
status: full cycles: 593
Info: model: Intel Core i5-7300U socket: BGA1356 (U3E1) note: check bits: 64
type: MT MCP arch: Amber/Kaby Lake note: check gen: core 7 level: v3
note: check built: 2017 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xF6
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 700 min/max: 400/3500 base/boost: 2600/2700 scaling:
driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
cores: 1: 700 2: 700 3: 700 4: 700 bogomips: 21599
Device-1: Intel HD Graphics 620 vendor: Lenovo driver: i915 v: kernel
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5916
Device-2: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 04f2:b5ac
class-ID: 0e02
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4 chip-ID: 04f2:b5ab
class-ID: 0e02
Display: unspecified server: X.Org v: 24.1.2 with: Xwayland v: 24.1.2
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: AU Optronics 0x103d built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 620 (KBL GT2)
device-ID: 8086:5916 memory: 3.62 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 620 (KBL GT2) driver: mesa intel v: 24.2.3-arch1.1
device-ID: 8086:5916 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.3-arch1.1 (LLVM
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.5 status: n/a (root, process) with:
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24fd
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
Local Storage: total: 238.47 GiB used: 21.4 GiB (9.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
lanes: 4 tech: SSD serial: <filter> fw-rev: 5111AALA temp: 30.9 C
scheme: MBR
SMART: yes health: PASSED on: 263d 17h cycles: 1,893
read-units: 52,597,179 [26.9 TB] written-units: 25,524,616 [13.0 TB]
ID-1: / raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
used: 21.4 GiB (9.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-2: /home raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
maj-min: 259:1
ID-3: /var/log raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
maj-min: 259:1
ID-4: /var/tmp raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
maj-min: 259:1
ID-1: swap-1 type: zram size: 7.41 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 52.0 C pch: 38.0 C mobo: N/A
Memory: total: 8 GiB note: est. available: 7.41 GiB used: 2.69 GiB (36.2%)
igpu: 32 MiB
Processes: 212 Power: uptime: 29m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.95 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1414 libs: 417 tools: octopi,paru Compilers:
gcc: 14.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.37
System install date: 2024-04-05
Last full system update: 2024-09-29
I’m trying to run this cronjob entry:
@reboot rclone mount --daemon GDrive:<path> /home/elia/DB
but as I say, when I write the above line into the temporary file (which is opened after “crontab -e” command) and then save it, nothing happens.
Other infos:
sudo crontab -l -u root
no crontab for root
sudo crontab -l -u elia
no crontab for elia
sudo cat /etc/crontab
# /etc/crontab: configuration file for cron
# See cron(8) and crontab(5) for details.
# m h dom mon dow user command
Also, these are journalctl entries for ‘cronie’ service after Garuda boot:
journalctl -u cronie
-- Boot 5b273b8a46c0419ba69c88ed86003029 --
set 29 19:33:06 elia-thinkpad systemd[1]: Started Command Scheduler.
set 29 19:33:06 elia-thinkpad crond[648]: (CRON) STARTUP (1.7.2)
set 29 19:33:06 elia-thinkpad crond[648]: (CRON) INFO (Syslog will be used instead of sendmail.)
set 29 19:33:06 elia-thinkpad crond[648]: (CRON) INFO (RANDOM_DELAY will be scaled with factor 74% if used.)
set 29 19:33:06 elia-thinkpad crond[648]: (CRON) INFO (running with inotify support)
set 29 20:01:00 elia-thinkpad CROND[5065]: (root) CMD (run-parts /etc/cron.hourly)
set 29 20:01:00 elia-thinkpad anacron[5073]: Anacron started on 2024-09-29
set 29 20:01:00 elia-thinkpad anacron[5073]: Will run job `cron.daily' in 49 min.
set 29 20:01:00 elia-thinkpad anacron[5073]: Will run job `cron.weekly' in 69 min.
set 29 20:01:00 elia-thinkpad anacron[5073]: Will run job `cron.monthly' in 89 min.
set 29 20:01:00 elia-thinkpad anacron[5073]: Jobs will be executed sequentially
set 29 20:01:01 elia-thinkpad CROND[5064]: (root) CMDEND (run-parts /etc/cron.hourly)
If I run manually 'rclone mount --daemon GDrive: /home/elia/DB it works as expected.
