Unable to boot using Garuda
Hi all, I’m starting to remove the windows drive from my computer and am unable to boot directly into Garuda without forcing boot selection on boot (F11). i suspect it is because my BIOS is not seeing Garuda as a boot drive and/or GRUB is not installed. Could I get some help with this please? Photos will be posted shortly to help explain.
Thanks
EDIT: Photos posted
Kernel: 6.15.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=febaf9ad-0482-4918-ab5a-fefa9211638a rw rootflags=subvol=@
Type: Desktop Mobo: MSI model: Z97S SLI Krait Edition (MS-7922) v: 2.0
UEFI: American Megatrends v: 10.6 date: 08/13/2015
Info: model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell
Speed (MHz): avg: 4270 min/max: 800/4400 scaling: driver: intel_cpufreq
governor: performance cores: 1: 4270 2: 4270 3: 4270 4: 4270 5: 4270 6: 4270
7: 4270 8: 4270 bogomips: 64003
Device-1: NVIDIA AD107 [GeForce RTX 4060] vendor: ASUSTeK driver: nvidia
v: 575.64 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2882 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-1 model: ASUS VG27V serial: <filter> built: 2020 res:
mode: 1920x1080 hz: 165 scale: 100% (1) dpi: 82 gamma: 1.2
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060/PCIe/SSE2
API: Vulkan v: 1.4.313 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4060 driver: nvidia v: 575.64 device-ID: 10de:2882
surfaces: N/A
Device-1: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-2: NVIDIA AD107 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:22be
API: ALSA v: k6.15.4-zen2-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 2.95 TiB used: 391.16 GiB (13.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 4H
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DX002-2DV164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 1TB
used: 391.16 GiB (42.0%) fs: btrfs dev: /dev/sdc2 maj-min: 8:34
used: 616 KiB (0.2%) fs: vfat dev: /dev/sdc1 maj-min: 8:33
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 52.0 C mobo: N/A
Memory: total: 32 GiB available: 31.28 GiB used: 2.96 GiB (9.4%)
Processes: 314 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1876 libs: 569 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: clang: 20.1.7 gcc: 15.1.1 Shell: garuda-inxi
default: fish v: 4.0.2 running-in: konsole inxi: 3.3.38
Garuda (2.7.3-1):
System install date:     2025-03-23
Last full system update: 2025-07-01
Hi
Can you set this to the First Boot Harddrive ? Save it and reboot should work.
I cannot set P2 to the first boot drive, or if I can, I have no idea which one in the list it is. The first photo is my applicable boot order for devices.
It must go to set as the Option 1 or look on the first override and click on it if you can chance there to the p2 drive. I can set it to first boot device but i have a asus boot menu not msi.
Pls bios update
https://www.msi.com/Motherboard/Z97S-SLI-Krait-Edition/support
Think on the right settings after update (secure boot off, fast boot off, ahci mode, uefi modus not csm)
boot order changing
https://www.msi.com/support/technical_details/MB_Boot_Priority
perhaps you see this option if you press F7 (inside bios)
But sorry..this you can find self default if you use your seach engine.
If only there were instructions for these things that could be included with the hardware in paper form.
:wink:
Search in MSI Forum.
There are some entries on the topic boot entry.
Msi insert a manual for the motherboard + 16gb usb bootstick with “all” drivers and infos.
unplug all power cord from ssds or put nvme out only left the garuda one in to see if its boots correctly restart few times and then plug other nvme or ssd back .
We dont know did you installed the boot to the windows drive?
Hi there, not sure if it was the BIOS flash, or a setting in the BIOS that I hadn’t seen before, but I managed to get it working, so thanks for the suggestion of the BIOS flash, as doing that led me to the solution.
