Unable to boot fresh install. Console: switching to colour frame buffer device 128x48
Hello, I have just built a new pc and I tried to install garuda Linux i3 on it (using the latest iso on fosshost) and when I try to boot it up for the first time it halts and the last thing it says is " Console: switching to colour frame buffer device 128x48". I just installed it and the installer didn't prompt me to use Nvidia or nouveau drivers for the GPU (idk if it's meant to). (Quick search said it was a probably a driver issue).
Specs are Intel 12400f, Nvidia 2080ti, Aorus z690i ultra lite ddr4. Note the CPU is igpu-less.
I didn't run the garuda-inxi command bc it isn't booting, but if necessary I can probably chroot with the live install media and run it, tho idk how useful that would be.
Thank you!
Welcome :slight_smile:
Try to install it with the free driver. You can change later to Nvidea.
If that does not help, work through this thread.
Yes please, Laptop/Notebook?
But use simple the live ISO, no chroot needed.
Very new Hardware?
    misobasedir=garuda misolabel=GARUDA_I3_TALON quiet systemd.show_status=1
    ibt=off systemd.unified_cgroup_hierarchy=1 driver=nonfree
    nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
  Desktop: i3 v: 4.21 info: i3bar vt: 7 dm: LightDM v: 1.32.0
  Type: Desktop System: Gigabyte product: Z690I A ULTRA LITE D4 v: -CF
  Mobo: Gigabyte model: Z690I A ULTRA LITE D4 serial: <superuser required>
    UEFI: American Megatrends LLC. v: F1 date: 04/08/2022
  Info: model: 12th Gen Intel Core i5-12400F bits: 64 type: MT MCP
    microcode: 0x22
    L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
    L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 1791 high: 2500 min/max: 800/5600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 2500 3: 2500
    4: 800 5: 801 6: 2500 7: 2500 8: 2500 9: 2500 10: 2500 11: 800 12: 800
    bogomips: 59904
  Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: eVga.com.
    driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
    process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1e07
  Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: nvidia
    unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia
  Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x333mm (23.70x13.11")
    s-diag: 688mm (27.09")
  Monitor-1: DP-2 res: 2560x1440 hz: 60 dpi: 109
    size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
  Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte
    driver: snd_hda_intel bus-ID: 1-2:2 v: kernel chip-ID: 0414:a014
    alternate: snd_sof_pci_intel_tgl class-ID: 0300 bus-ID: 00:1f.3
  Device-2: NVIDIA TU102 High Definition Audio vendor: eVga.com.
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f7
  Device-3: Giga-Byte USB Audio type: USB
  Device-1: Intel Alder Lake-S PCH CNVi WiFi vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
  Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
  IF: enp3s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
    bus-ID: 1-14:9 chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 1.41 TiB used: 25.22 GiB (1.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO
    500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7
    temp: 32.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
  ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra
    size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: N/A
  ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston model: USB DISK
    2.0 size: 14.43 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: PMAP scheme: MBR
  ID-1: swap-1 type: zram size: 31.19 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 37 C
  Processes: 334 Uptime: 27m wakeups: 68 Memory: 31.19 GiB used: 4.04 GiB
  (13.0%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1230 libs: 303
  tools: pamac,paru Shell: Bash v: 5.1.16 running-in: xfce4-terminal
  inxi: 3.3.22
Garuda (2.6.8-1):
  System install date:     2022-11-30
  Last full system update: 2022-11-29 ↻
this hardware is a desktop, and new, however the gpu is old. the installer didn't give me the option to install with Nvidia or noveau drivers. I just reinstalled it to verify.
When you start the live ISO you have the choice, later in the Calamares installer you don't.
The Nvidia driver seems to have been installed, but there are currently problems with it.
Ah, i understand, will try that now thank you.
It booted, Thank you very much!
