Hey everyone,
I have recently started gaming on my machine, and everything is running great thanks to Proton. I have been able to boot and play Cyberpunk with no issues, however, I noticed while poking around in the graphics setting in the game that RTX ray tracing and DLSS are unable to be turned on. After some research, it seems like it might just not be possible to activate them on Linux because of stuff on Nvidia's end and possible communication issues with Proton, but I wanted to ask the community here if there was something I am missing that will let me activate them. I realize they are ultimately unnecessary, but it feels like wasted potential on my machine's part. After all, making things aggressively pretty is half the point of gaming on a PC right?
As a side note, if anyone has a good option for controlling what the GPU does, I would love some advice. Only thing I was able to use in the past was the GreenWithEnvy program, but now that doesn't launch. I know Nvidia has a native program (GeForce) but that seems to only work on windows. I found I can monitor the GPU just fine from System Monitor, but I can't find a good way to actually manipulate settings. Only thing that comes close is the Nvidia X Server Settings, but that is pretty limited.
Feel free to link me anything. I am as green as they come. Any and all advice is appreciated, and happy holidays from the States!
Kernel: 5.15.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5ce6276f-6096-415f-8b7e-9ce6e1cbd299 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3603
date: 03/20/2021
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4191 high: 4210 min/max: 2200/5619 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4191 2: 4200
3: 4200 4: 4172 5: 4210 6: 4185 7: 4195 8: 4207 9: 4198 10: 4206 11: 4176
12: 4165 13: 4192 14: 4161 15: 4199 16: 4194 17: 4183 18: 4186 19: 4181
20: 4198 21: 4200 22: 4199 23: 4192 24: 4203 bogomips: 201596
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti] driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 09:00.0 chip-ID: 10de:2486
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 2560x1440 s-dpi: 108 s-size: 602x342mm (23.7x13.5")
s-diag: 692mm (27.3")
Monitor-1: DP-0 res: 2560x1440 hz: 144 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 09:00.1 chip-ID: 10de:228b class-ID: 0403
driver: snd_hda_intel v: kernel bus-ID: 0b:00.4 chip-ID: 1022:1487
Sound Server-1: ALSA v: k5.15.8-zen1-1-zen running: yes
Device-1: Intel Wireless-AC 9260 driver: iwlwifi v: kernel bus-ID: 04:00.0
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus-ID: 05:00.0
v: 0.8 bus-ID: 3-5:2 chip-ID: 8087:0025 class-ID: e001
address: <filter>
Local Storage: total: 465.76 GiB used: 129.84 GiB (27.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P2SSD8
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P2CR033
temp: 38.9 C scheme: GPT
ID-1: / raw-size: 465.5 GiB size: 465.5 GiB (100.00%)
used: 129.84 GiB (27.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 465.5 GiB size: 465.5 GiB (100.00%)
ID-4: /var/log raw-size: 465.5 GiB size: 465.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 465.5 GiB size: 465.5 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.59 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 44 C
Processes: 423 Uptime: 37m wakeups: 0 Memory: 15.59 GiB
used: 3.27 GiB (21.0%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1757 lib: 529 Shell: fish v: 3.3.1
default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.10
