Yes, the part before “Second try” didn’t work for me as well.
Yes, I used your guide to Load Modules: sudo modprobe -a binder-linux ashmem-linux (which was the part which was not working above, with the ReDroid procedure/script.
This happened to me only using zen kernel, while it worked using the linux-cacule kernel.
But be careful, in the terminal / docker nothing will show up, apart from the ID of your instance, and in my case a couple of error message that at a quick look on the Internet could be disregarded.
To open the “Android” you should have a VNC client (I use TigerVNC), open it and connect with YourIPaddress:5900
Graphically OK but with a bad standard resolution 720x1280, which can be changed passing additional parameters in the docker command, e.g. redroid.width=XXXX redroid.height=YYYY e.g. after -p 5555:5555
It’s really worth studying it.
For a certain period I had to use it with other distros (but it shouldn’t change much, you should only be careful with some aspects of brtfs, if insterested just search on the forum).
To give you an example, there was a solution I had to use composed by 6 or 7 modules/systems (a web server, a DB server, etc. etc., all configured to work one with each other). I followed the standard procedure and it took a whole day to compile/install, when I found the docker equivalent just the time to copy and paste a string…
no, the command should remain as is, there you define the ports.
check your ip address and connect with e.g. in the appropriate TigerVNC field 192.168.1.125:5900
$ docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
4197c18715b5 redroid/redroid:10.0.0-latest "/init qemu=1 androi…" 2 minutes ago Up 2 minutes 0.0.0.0:5555->5555/tcp, :::5555->5555/tcp elegant_hopper
What does this mean, I can't see any graphical interface
The scrcpy method works for, the container is even recognized by guiscrcpy. However its incredible slow compared to Anbox & input is delayed for some reason
There is now a anbox-support package which pulls dependencies, sets the required configs in place and gives instructions how to complete the setup (/etc/fstab for example needs to be edited manually), thought that might help
It seems like my own instructions aren't working for me now (lol),
Anbox nor running in both xanmod and cacule, I tried a Garuda reinstall, still not working.
Is any body else facing this issue?
We need logs. But you are right, it doesnt work for me either right now. Looking at the systemd logs I get this:
Mai 03 10:44:53 T440p-void systemd[2536]: Started Anbox Session Manager.
Mai 03 10:44:54 T440p-void anbox[2543]: Failed to initialize EGL
Mai 03 10:44:54 T440p-void anbox[2543]: Failed to start container: Failed to start container: Failed to set config item lxc.group.devices.deny
Mai 03 10:44:54 T440p-void anbox[2543]: Lost connection to container manager, terminating.
Mai 03 10:44:54 T440p-void anbox[2543]: Container is not running
Mai 03 10:44:54 T440p-void anbox[2543]: Stack trace (most recent call last) in thread 2897:
Mai 03 10:44:54 T440p-void anbox[2543]: #5 Object "", at 0xffffffffffffffff, in
Mai 03 10:44:54 T440p-void systemd[2536]: anbox-session-manager.service: Main process exited, code=exited, status=1/FAILURE
Mai 03 10:44:54 T440p-void systemd[2536]: anbox-session-manager.service: Failed with result 'exit-code'.
which is pretty much the same issue reported here:
Best thing to do is to keep track of the issues
Edit: downgrading lxc to 4.0.6 is indeed a temporary fix, taken from above linked issue
Anbox has really pushed me to the limits of my sanity in getting it to work....and I LOVE that.
I guess it's what defines me as a linux user. This is a great project and I love being a Garuda user who is able to stay on top of it as things are changed and updated.
Hi, did you try the GPU options? the redroid rendering with swiftshader (software) by default, and it's pretty slow. you can enable GPU options just like the doc says. Anbox rendering with GLES Host emulation (API forward with socket), and redroid can rendering with DRM directly (which should much more efficient). the redroid projects are still in early stage, and there are much work to do (libva to accelerate media codec; auto detect GPU and fallback to soft etc.).
You need to downgrade to lxc 4.0.6, get all required configs in place by installing anbox support and enable both systemd services then it should work, linux-cacule is compatible ( tested )
Same with me. I tried replacing binder_linux in the command: lsmod | grep -e ashmem_linux -e binder_linux with binderfs_linux, binder and binderfs . But it didn't work
run this command sudo ls -1 /dev/{ashmem,binderfs}
