Can’t get my bluetooth dongle to work it just doesn’t detect any devices and enable option does not seem to do anything the Bluetooth dongle is model CM748. Chip ATS2851 . Already uninstalled it from Windows 11.
Running Garuda Linux Kernel 6.16.4-zen1-1-zen.
Kernel: 6.16.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=dc0cf298-2dd0-4a05-933d-71a6bbbee6c8 rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A wm: kwin_wayland
with: ulauncher dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: TUF Z270 MARK 2 v: Rev 1.xx
serial: <filter> part-nu: SKU uuid: 1be5b0e0-3446-11e7-8d40-6045cba53b61
UEFI: American Megatrends v: 1301 date: 03/14/2018
Info: model: Intel Core i7-7700K socket: LGA1151 bits: 64 type: MT MCP
arch: Kaby Lake gen: core 7 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
microcode: 0xF8
Speed (MHz): avg: 800 min/max: 800/4500 base/boost: 4200/8300 scaling:
driver: intel_pstate governor: powersave volts: 1.1 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
bogomips: 67200
Device-1: Intel HD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: none
empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5912 class-ID: 0380
Device-2: Advanced Micro Devices [AMD/ATI] Navi 14 [Radeon RX 5500/5500M
/ Pro 5500M] vendor: XFX Pine driver: amdgpu v: kernel arch: RDNA-1
code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-3 empty: DP-1,DP-2,DP-3
bus-ID: 03:00.0 chip-ID: 1002:7340 class-ID: 0300
Display: unspecified server: X.Org v: 24.1.8 with: Xwayland v: 24.1.8
compositor: kwin_wayland driver: gpu: amdgpu display-ID: :0 screens: 1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-3 model: ViewSonic VX2479 Series serial: <filter>
built: 2024 res: mode: 1920x1080 hz: 180 scale: 100% (1) dpi: 93 gamma: 1.2
API: EGL v: 1.5 hw: drv: intel iris drv: amd radeonsi platforms: device: 0
drv: radeonsi device: 1 drv: iris device: 2 drv: swrast gbm: drv: radeonsi
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5500 XT (radeonsi
navi14 LLVM 20.1.8 DRM 3.64 6.16.5-zen1-1-zen) device-ID: 1002:7340
memory: 3.91 GiB unified: no
API: Vulkan v: 1.4.321 layers: 5 device: 0 type: discrete-gpu name: AMD
Radeon RX 5500 XT (RADV NAVI14) driver: mesa radv v: 25.2.2-arch1.1
device-ID: 1002:7340 surfaces: N/A device: 1 type: integrated-gpu
name: Intel HD Graphics 630 (KBL GT2) driver: mesa intel v: 25.2.2-arch1.1
device-ID: 8086:5912 surfaces: N/A device: 2 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.2-arch1.1 (LLVM
Device-2: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38 class-ID: 0403
API: ALSA v: k6.16.5-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.7 status: n/a (root, process) with:
Device-1: USB2.0-BT driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-8:7 chip-ID: 33fa:0010 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: N/A
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f060
bus-ID: 00:17.0 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 5.24 TiB used: 832.81 GiB (15.5%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
fw-rev: 102000WD temp: 40.9 C scheme: GPT
SMART: yes health: PASSED on: 2y 184d 1h cycles: 2,833
read-units: 131,403,817 [67.2 TB] written-units: 165,809,723 [84.8 TB]
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Western Digital
model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 234110WD temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 323d 8h cycles: 1,000
read-units: 11,612,240 [5.94 TB] written-units: 5,591,253 [2.86 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: ASUS model: Rogueware 2.5 SATA NX100S
256GB size: 238.47 GiB block-size: physical: 512 B logical: 512 B
sata: 3.2 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 8B0
temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 263d 18h cycles: 866
read: 31.4 MiB written: 28.3 MiB
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000DM007-1WY10G
family: BarraCuda 3.5 (SMR) size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD rpm: 5425
serial: <filter> fw-rev: 0001 temp: 31 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 26702h+52m+42.375s
cycles: 3546 read: 16.83 TiB written: 20.25 TiB Pre-Fail:
attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: BUP Slim BK
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 0107 scheme: MBR
SMART Message: A mandatory SMART command failed. Various possible causes.
ID-1: / raw-size: 118.14 GiB size: 118.14 GiB (100.00%)
used: 6.95 GiB (5.9%) fs: btrfs block-size: 4096 B dev: /dev/sda7
maj-min: 8:7
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 33.7 MiB (35.5%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p2
maj-min: 259:3
ID-3: /home raw-size: 118.14 GiB size: 118.14 GiB (100.00%)
maj-min: 8:7
ID-4: /var/log raw-size: 118.14 GiB size: 118.14 GiB (100.00%)
maj-min: 8:7
ID-5: /var/tmp raw-size: 118.14 GiB size: 118.14 GiB (100.00%)
maj-min: 8:7
ID-1: swap-1 type: zram size: 31.08 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
mem: 0.0 C
Memory: total: 32 GiB available: 31.08 GiB used: 3.58 GiB (11.5%)
Processes: 326 Power: uptime: 43m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.4 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1229 libs: 308 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash (sudo) v: 5.3.3 running-in: konsole inxi: 3.3.39
Garuda (2.8.2-2):
System install date: 2025-09-05
Last full system update: 2025-09-06 ↻
Windows dual boot: Yes
23/23 checks run in 1.16 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
- Failed systemd services found: systemd-vconsole-setup.service
--- INFO ---
