Hello everybody,
I start using Garuda Linux in may 2022 and enjoy it a lot.
I have a 2 monitors setup: HDMI: 1920x1200_60Hz + DP: 3440x1440_75 Hz
ISSUE:
I would appreciate some advice with this issue, I start having with the upgrade to Plasma 5.26 and Nvidia driver 520 ( garuda-dr460nized-linux-zen-221019.iso ):
When I booth the system or wake it up from sleep,
- Only the 1900x1200 display light up. The 3440x1440 stay dark
- The system tray display configuration icon, slowly flash
- The 3440x1440 display appear and disappear in the System Settings/Display and Monitor
Temporary Fix :
Open the system tray/display configuration, an repeatedly click like crazy the 2 displays right icon, till the 3440x1440 display wake-up from the dead.
Note: When in the grub, I choose “Advance options” and pick the first choice, it sometime work, but after a few boot, it may be the reverse and it's the “Garuda Linux” option that start working!…..
What I've tried:
1 - Booting in Windows 11 or Garuda Gnome on other SSD - No display issue, it work's fine!
2 - Changing the DP connection port on the graphic card - No success;
3 - Fresh install of garuda-dr460nized-linux-zen-221019.iso - No success;
4 - After sudo nvidia-settings in the terminal and setting the Xserver Display Configuration correctly, I save to /etc/X11/xorg.conf - No success.
/etc/X11/xorg.conf FIle:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 520.56.06
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "DELL U2412M"
HorizSync 30.0 - 83.0
VertRefresh 50.0 - 61.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce GTX 980 Ti"
EndSection
Section "Screen"
# Removed Option "metamodes" "HDMI-0: nvidia-auto-select +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}, DP-4: nvidia-auto-select +1920+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-6"
Option "metamodes" "HDMI-0: 1920x1200_60 +0+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}, DP-4: 3440x1440_75 +1920+0 {ForceCompositionPipeline=On, ForceFullCompositionPipeline=On}"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
â•─jlt@jlt in ~ as đź§™ took 2s
╰─λ garuda-inxi
Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=9bf24b65-7ac7-4983-a52a-cc65570b547d rw rootflags=subvol=@
splash rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop System: EVGA product: X570 DARK v: N/A
Mobo: EVGA model: X570 DARK v: 1.2.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: 1.08 date: 12/12/2012
ID-1: hidpp_battery_0 charge: 100% condition: N/A volts: 4.2 min: N/A
model: Logitech Gaming Mouse G900 type: N/A serial: <filter> status: full
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3566 high: 4675 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
3: 3400 4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 4055 11: 3737
12: 3734 13: 3400 14: 4673 15: 3400 16: 3400 17: 3400 18: 3400 19: 3400
20: 3400 21: 3400 22: 3400 23: 3400 24: 3400 25: 3400 26: 3400 27: 3400
28: 3400 29: 3400 30: 4675 31: 4174 32: 4086 bogomips: 217603
Device-1: NVIDIA GM200 [GeForce GTX 980 Ti] vendor: ASUSTeK driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 0b:00.0 chip-ID: 10de:17c8 class-ID: 0300
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 95 s-size: 513x321mm (20.20x12.64")
s-diag: 605mm (23.82")
Monitor-1: DP-4 size-res: N/A modes: N/A
Monitor-2: HDMI-0 pos: primary res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce GTX 980
Ti/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GM200 High Definition Audio vendor: ASUSTeK
bus-ID: 0b:00.1 chip-ID: 10de:0fb0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: eVga.com.
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
Device-3: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
IF-ID-1: eno1 state: up speed: 2500 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-1:2
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 2.27 TiB used: 629.03 GiB (27.0%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
model: WDS200T1X0E-00AFY0 size: 1.82 TiB block-size: physical: 512 B
rev: 614900WD temp: 31.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 29.9 C scheme: GPT
ID-1: / raw-size: 117.19 GiB size: 117.19 GiB (100.00%)
used: 21.39 GiB (18.3%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:7
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:6
ID-3: /home raw-size: 383.01 GiB size: 383.01 GiB (100.00%)
used: 41.38 GiB (10.8%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:4
ID-4: /var/log raw-size: 117.19 GiB size: 117.19 GiB (100.00%)
ID-5: /var/tmp raw-size: 117.19 GiB size: 117.19 GiB (100.00%)
System Temperatures: cpu: 57.4 C mobo: N/A gpu: nvidia temp: 37 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 41%
Processes: 535 Uptime: 2m wakeups: 2 Memory: 31.27 GiB used: 2.67 GiB (8.6%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1497 libs: 366
tools: octopi,pamac,paru,yay Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-10
Last full system update: 2022-11-11
Journal Errors
â•─jlt@jlt in ~
╰─λ sudo journalctl -p 3 -xb
[sudo] password for jlt:
Nov 11 14:50:44 jlt-GLPlasma kernel:
Nov 11 14:50:45 jlt-GLPlasma bluetoothd[841]: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
Nov 11 14:50:45 jlt-GLPlasma bluetoothd[841]: src/adapter.c:set_device_privacy_complete() Set device flags return status: Invalid Parameters
Nov 11 14:50:53 jlt-GLPlasma systemd[3823]: Failed to start Profile-sync-daemon.
â–‘â–‘ Subject: A start job for unit UNIT has failed
â–‘â–‘ Defined-By: systemd
â–‘â–‘ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
â–‘â–‘
â–‘â–‘ A start job for unit UNIT has finished with a failure.
â–‘â–‘
â–‘â–‘ The job identifier is 27 and the job result is failed.
Nov 11 14:50:56 jlt-GLPlasma systemd[3823]: Failed to start BTRFS Assistant Snapper check.
â–‘â–‘
â–‘â–‘
â–‘â–‘ The job identifier is 93 and the job result is failed.
Nov 11 14:51:06 jlt-GLPlasma bluetoothd[841]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Nov 11 14:51:10 jlt-GLPlasma sudo[5657]: jlt : a password is required ; TTY=pts/0 ; PWD=/home/jlt ; USER=root ; COMMAND=/usr/bin/true
Nov 11 14:51:11 jlt-GLPlasma bluetoothd[841]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Thank's for your help,
JL
P.S. Please forgive my English
