Garuda-Inxi:
```text
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
root=UUID=e7454ee6-b5e4-487a-b0dc-d8af91efa048 rw rootflags=subvol=@ quiet loglevel=3
amdgpu.ppfeaturemask=0xffffffff ibt=off
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0 wm: kwin_wayland vt: 1
Type: Desktop Mobo: ASRock model: B650M PG Riptide serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.11 date: 10/21/2022
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 5 level: v4 note: check
built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x61 (97) stepping: 2
microcode: 0xA601203
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4218 high: 5509 min/max: 400/5573 scaling: driver: amd-pstate-epp
governor: performance cores: 1: 5488 2: 400 3: 5490 4: 400 5: 5509 6: 5490 7: 400 8: 5495 9: 5480
10: 5486 11: 5487 12: 5492 13: 5489 14: 5484 15: 400 16: 5506 bogomips: 143732
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX/7900M] vendor: Tul / PowerColor driver: amdgpu
v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:744c class-ID: 0300
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4 compositor: kwin_wayland
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 res: 3840x2160 size: N/A modes: N/A
surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi navi31 LLVM 17.0.6 DRM 3.57
6.8.1-zen1-1-zen) device-ID: 1002:744c memory: 19.53 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD Radeon RX 7900 XT
(RADV NAVI31) driver: mesa radv v: 24.0.3-arch1.1 device-ID: 1002:744c
surfaces: xcb,xlib,wayland device: 1 type: cpu name: llvmpipe (LLVM 17.0.6 256 bits)
driver: mesa llvmpipe v: 24.0.3-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Elgato Systems GmbH Wave:1 driver: snd-usb-audio type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 0fd9:006e class-ID: fe01 serial: <filter>
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: e000 bus-ID: 09:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-10:5 chip-ID: 0b05:190e class-ID: e001 serial
: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter> bt-v: 5.1 lmp-v: 10 status: discoverable: no
pairing: no
Local Storage: total: 1.82 TiB used: 1.59 TiB (87.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000T700SSD5 size: 1.82 TiB
block-size: physical: 512 B logical: 512 B speed: 126 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: PACR5101 temp: 43.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.59 TiB (87.2%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.59 TiB (87.2%) fs: btrfs
ID-4: /var/log raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.59 TiB (87.2%) fs: btrfs
ID-5: /var/tmp raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.59 TiB (87.2%) fs: btrfs
ID-1: swap-1 type: zram size: 31.05 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
System Temperatures: cpu: 53.0 C mobo: N/A gpu: amdgpu temp: 43.0 C mem: 52.0 C
Memory: total: 32 GiB note: est. available: 31.06 GiB used: 5.08 GiB (16.4%)
Processes: 404 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle wakeups: 0
hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.41 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 255
Packages: pm: pacman pkgs: 1936 libs: 504 tools: octopi,paru,yay Compilers: clang: 17.0.6
gcc: 13.2.1 Client: shell wrapper v: 5.2.26-release inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-10-29
Last full system update: 2024-03-17
My upgrade to KDE 6 has been nearly flawless, but I am getting 2 minor issues even a few weeks later. One, System monitor seems to be counting my boot drive twice, showing a total space of 3.6 terabytes, not 1.8 like it should. Device viewer only shows the one drive of the correct size and its 3 partitions. Should I be worried about drive failure/corruption?
The second is I’ve been getting a regular stutter when watching videos of any kind(youtube, zoom webcam, etc) that seems to take over the whole system, lasting a few seconds every time. This did not happen in Plasma 5. I’m used to it dropping hella frames because google throttles me due to my adblocker, but not whole stutters.
