Hi! Brand new to Garuda and to Linux in general. As seems to be common, my backlight controls aren’t working. After a lot of trial and error, I’ve figured out what the problem is, but not how to solve it.
In my sys/class/backlight directory, there are two subfolders: /amdgpu_bl2, and /nvidia_0. I’ve figured out that amdgpu_bl2 is the correct device to modify, but every method of controlling my backlight brightness modifies nvidia_0. For example, I’ve successfully modified my screen brightness with “brightnessctl --device=amdgpu_bl2 s 40%” but the generic command “brightnessctl s 40%” sets nvidia_0 to 40% (which does nothing). The backlight icon in the Waybar displays the brightness value from amdgpu_bl2, but it, too, seems to be stuck modifying the value of nvidia_0.
I’ve found a few solutions listed for problems similar to this, but all of them were fixed by users appending the kernel parameter “acpi_backlight=vendor” or “use_native_backlight=1”; neither of these did much of anything for me. If it helps, acpi_backlight=vendor did change how my backlight controls worked (the value in the Waybar now changes), but it did not let me control the backlight itself.
I’m certain this is at least partially because I’m on an unsupported GPU, but I have no idea how to proceed from here. Any help would be appreciated!
Kernel: 6.12.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=85410ea9-baf0-4f7d-9954-99fccaf1ba24 rw rootflags=subvol=@
quiet resume=UUID=58b67e2f-f052-4a7e-aa85-7a546ee72558 loglevel=3 ibt=off
Desktop: Sway v: 0.4 with: waybar tools: swayidle avail: swaylock vt: 1
lm: greetd Distro: Garuda base: Arch Linux
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> part-nu: LENOVO_MT_82B5_BU_idea_FM_Legion 5
15ARH05 uuid: <superuser required> UEFI: LENOVO v: EUCN41WW
date: 09/20/2023
ID-1: BAT0 charge: 52.2 Wh (100.0%) condition: 52.2/60.0 Wh (87.0%)
volts: 17.3 min: 15.4 model: SMP L19M4PC0 type: Li-poly serial: <filter>
status: full cycles: 83
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
microcode: 0x860010D
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 3000 min/max: 1400/3000 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 3000 2: 3000 3: 3000
4: 3000 5: 3000 6: 3000 7: 3000 8: 3000 9: 3000 10: 3000 11: 3000 12: 3000
bogomips: 71862
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
driver: nvidia v: 565.77 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
empty: DP-1,HDMI-A-1,eDP-1 bus-ID: 01:00.0 chip-ID: 10de:1f95
Device-2: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-2 empty: none bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 33.0 C
Device-3: Realtek USB Boot driver: N/A type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 0bda:5846 class-ID: 0e02
Display: wayland server: Xwayland v: 24.1.4 compositor: Sway v: 0.4
driver: gpu: amdgpu display-ID: 1
Monitor-1: eDP-2 model: BOE Display 0x08e8 built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 scale: 1 size: 344x194mm (13.54x7.64")
drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: radeonsi
x11: drv: radeonsi
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: amd mesa v: 24.3.1-arch1.3
renoir LLVM 18.1.8 DRM 3.59 6.12.4-zen1-1-zen) device-ID: 1002:1636
memory: 500 MiB unified: no
API: Vulkan v: 1.4.303 layers: 11 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1636
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 Ti driver: N/A device-ID: 10de:1f95
Device-1: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
vendor: Lenovo driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.4-zen1-1-zen status: kernel-api with: aoss
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 8087:0029
Local Storage: total: 1.14 TiB used: 690.96 GiB (59.1%)
model: MZVLB256HBHQ-000L2 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 3L1QEXH7 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPSX-08A6W
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 102.59 GiB (44.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 7.13 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.1 C mobo: N/A gpu: amdgpu temp: 34.0 C
Memory: total: 8 GiB note: est. available: 7.13 GiB used: 3.31 GiB (46.5%)
Processes: 397 Power: uptime: 22m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.77 GiB services: upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1700 libs: 531 tools: pacseek,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: foot inxi: 3.3.36
System install date: 2024-12-17
Last full system update: 2024-12-19
