I've tried installing it with pacman, and through the github. All my searches get "no results!"
Any suggestions?
Kernel: 5.18.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f9ef267e-8b7f-41b0-afed-b96ded78cd39 rw [email protected]
resume=UUID=08d8a7c4-2f5d-44df-acb6-3606b2cfa700 loglevel=3 ibt=off
Type: Desktop Mobo: ASRock model: A320M-HDV R4.0
serial: <superuser required> UEFI: American Megatrends v: P3.30
date: 07/31/2019
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
built: 2018-21 process: GF 12nm family: 0x17 (23) model-id: 8 stepping: 2
microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2593 high: 3395 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2416 2: 2408
3: 2235 4: 2606 5: 2411 6: 2998 7: 2676 8: 2690 9: 2320 10: 2302 11: 2667
12: 3395 bogomips: 81586
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: ZOTAC driver: nvidia
v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 06:00.0
chip-ID: 10de:2184 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
Screen-1: 0 s-res: 7680x2160 s-dpi: 101 s-size: 1930x543mm (75.98x21.38")
s-diag: 2005mm (78.93")
Monitor-1: DP-1 pos: primary,top-center res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.39x12.76") diag: 611mm (24.05") modes: N/A
Monitor-2: DP-2 pos: bottom-l res: 1920x1200 hz: 60 dpi: 94
Monitor-3: HDMI-0 pos: top-right res: 3840x2160 hz: 60 dpi: 52
size: 1872x1053mm (73.7x41.46") diag: 2148mm (84.56") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1660/PCIe/SSE2
v: 4.6.0 NVIDIA 515.48.07 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: ZOTAC
bus-ID: 06:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 08:00.3
Sound Server-1: ALSA v: k5.18.2-zen1-1-zen running: yes
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: ASUSTeK driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 04:00.0 chip-ID: 168c:003e class-ID: 0280
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: ASUSTek type: USB driver: btusb v: 0.8 bus-ID: 1-9:2
chip-ID: 0b05:1868 class-ID: e001
Local Storage: total: 1.95 TiB used: 44.14 GiB (2.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 500GB SSD
type: SSD serial: <filter> rev: 0613 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: HD642JJ
size: 596.17 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: 1114 scheme: MBR
ID-1: / raw-size: 111.76 GiB size: 111.76 GiB (100.00%)
used: 30.75 GiB (27.5%) fs: btrfs dev: /dev/sdb3 maj-min: 8:19
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 815.43 GiB size: 815.43 GiB (100.00%)
used: 13.39 GiB (1.6%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
ID-4: /var/log raw-size: 111.76 GiB size: 111.76 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.76 GiB size: 111.76 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 512 KiB (0.0%)
ID-2: swap-2 type: partition size: 3.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 44 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
Processes: 342 Uptime: 2h 20m wakeups: 0 Memory: 31.28 GiB
used: 4.44 GiB (14.2%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1974
lib: 556 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.17
Garuda (2.6.3-2):
System install date: 2021-12-01
Last full system update: 2022-06-13 ↻
