Hello
I am in need of turbo c++ for my laptop.
I tried looking for download procedure, did find for other distros.
There did not seem to be any for arch or garuda linux( I might've overlooked).
So is there a way so that I can install turbo c++ and compile c++ programs ?
System: Kernel: 5.14.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f819063d-b089-4096-baf5-3d2eb4e8d8de
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: LENOVO product: 81MT v: Lenovo V145-15AST serial: <filter> Chassis:
type: 10 v: Lenovo V145-15AST serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <filter> UEFI-[Legacy]: LENOVO
v: 8ZCN27WW(V2.06) date: 01/12/2021
Battery: ID-1: BAT1 charge: 25.9 Wh (100.0%) condition: 25.9/30.0 Wh (86.5%) volts: 8.6 min: 7.5
model: 0x53 0x4D 0x50 0x00 0x31 0x PABAS0241231 type: Li-ion serial: <filter> status: Charging
cycles: 436
CPU: Info: Dual Core model: AMD A6-9225 RADEON R4 5 COMPUTE CORES 2C+3G bits: 64 type: MCP
arch: Excavator family: 15 (21) model-id: 70 (112) stepping: 0 microcode: 6006705 cache:
L2: 1024 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 10380
Speed: 2476 MHz min/max: 1300/2600 MHz boost: enabled Core speeds (MHz): 1: 2476 2: 2373
Graphics: Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
Device-2: Syntek EasyCamera type: USB driver: uvcvideo bus-ID: 1-1.3:4 chip-ID: 174f:241a
class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Monitor-2: HDMI-A-0 res: 1366x768 hz: 60 dpi: 57 size: 609x347mm (24.0x13.7")
diag: 701mm (27.6")
OpenGL: renderer: AMD STONEY (DRM 3.42.0 5.14.12-zen1-1-zen LLVM 12.0.1) v: 4.5 Mesa 21.2.3
direct render: Yes
Audio: Device-1: AMD vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:15b3
Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:09.2
chip-ID: 1022:157a class-ID: 0403
Sound Server-1: ALSA v: k5.14.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: N/A
modules: r8169 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo
driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c821
IF-ID-1: enp0s16u2 state: unknown speed: -1 duplex: half mac: <filter>
Bluetooth: Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 1-1.2:3
chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 5 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Device-2: Qualcomm Mobile Router type: USB driver: rndis_host v: kernel bus-ID: 2-2:10
chip-ID: 05c6:f00e class-ID: 0a00 serial: <filter>
Drives: Local Storage: total: 931.51 GiB used: 53.69 GiB (5.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0E
scheme: MBR
Partition: ID-1: / raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 53.69 GiB (5.8%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 53.69 GiB (5.8%) fs: btrfs
ID-3: /var/log raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 53.69 GiB (5.8%) fs: btrfs
ID-4: /var/tmp raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 53.69 GiB (5.8%) fs: btrfs
ID-1: swap-1 type: zram size: 3.72 GiB used: 1 GiB (26.9%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 69.6 C mobo: N/A gpu: amdgpu temp: 69.0 C
Info: Processes: 230 Uptime: 11h 11m wakeups: 270 Memory: 3.72 GiB used: 3 GiB (80.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1630 lib: 490
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Thank you in advance.
