Tube-converter close automatically after clicking validate on Kde
Hello !
╰─λ garuda-inxi
Kernel: 6.3.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=373b505e-0101-42f9-9423-26c00f9385dc rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 1
Type: Laptop System: HP product: HP EliteBook 840 G4 v: N/A
Mobo: HP model: 828C v: KBC Version 45.52 serial: <superuser required>
UEFI: HP v: P78 Ver. 01.45 date: 12/15/2022
ID-1: BAT0 charge: 11.8 Wh (26.8%) condition: 44.1/51.3 Wh (86.0%)
volts: 11.2 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 613
Info: model: Intel Core i5-7300U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF2
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 400/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 21599
Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
Device-2: Cheng Uei Precision Industry (Foxlink) HP HD Camera
driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-9:3 chip-ID: 05c8:0397 class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 model: AU Optronics 0x123d built: 2013 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.2 renderer: Mesa Intel HD Graphics 620 (KBL
GT2) direct-render: Yes
API: ALSA v: k6.3.9-zen1-1-zen status: kernel-api tools: N/A
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:2 chip-ID: 8087:0a2b
address: <filter>
Local Storage: total: 238.47 GiB used: 34.82 GiB (14.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Micron model: MTFDDAV256TBN-1AR15ABHA
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0T12 scheme: GPT
ID-1: / raw-size: 15 GiB size: 15 GiB (100.00%) used: 8.71 GiB (58.1%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 182.99 GiB size: 182.99 GiB (100.00%)
used: 1.82 GiB (1.0%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 15 GiB size: 15 GiB (100.00%)
used: 8.71 GiB (58.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-5: /var/tmp raw-size: 15 GiB size: 15 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.64 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C pch: 37.5 C mobo: N/A
Processes: 253 Uptime: 1h 1m wakeups: 3 Memory: available: 7.64 GiB
used: 3.82 GiB (50.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1234
libs: 333 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date:     2023-06-22
Last full system update: 2023-06-24
running from terminal :
tubeconverter
(process:27528): Gtk-WARNING **: 22:43:59.795: Theme parser error: gtk-dark.css:4957:10-13: Expected a valid c
olor.
(process:27528): Gtk-WARNING **: 22:43:59.795: Theme parser error: gtk-dark.css:4965:10-13: Expected a valid c
olor.
(process:27528): Gtk-WARNING **: 22:43:59.795: Theme parser error: gtk-dark.css:5026:10-13: Expected a valid c
olor.
(process:27528): Gtk-WARNING **: 22:43:59.795: Theme parser error: gtk-dark.css:5031:10-13: Expected a valid c
olor.
(process:27528): Gtk-WARNING **: 22:43:59.796: Theme parser error: gtk-dark.css:5150:10-13: Expected a valid c
olor.
(process:27528): Gtk-WARNING **: 22:43:59.796: Theme parser error: gtk-dark.css:5155:10-13: Expected a valid c
olor.
(process:27528): Adwaita-WARNING **: 22:43:59.818: Using GtkSettings:gtk-application-prefer-dark-theme with li
badwaita is unsupported. Please use AdwStyleManager:color-scheme instead.
Python.Runtime.PythonException: 'width'
at Python.Runtime.PythonException.ThrowLastAsClrException()
at Python.Runtime.PyObject.GetItem(PyObject key)
at Python.Runtime.PyObject.GetItem(String key)
at Python.Runtime.PyObject.get_Item(String key)
at NickvisionTubeConverter.Shared.Models.MediaUrlInfo.ParseFormats(PyDict mediaInfo) in /home/os/.cache/par
u/clone/tube-converter/src/tubeconverter/NickvisionTubeConverter.Shared/Models/MediaUrlInfo.cs:line 125
at NickvisionTubeConverter.Shared.Models.MediaUrlInfo.ParseFromPyDict(Object yt, PyDict mediaInfo, Boolean
isPartOfPlaylist, String defaultUrl) in /home/os/.cache/paru/clone/tube-converter/src/tubeconverter/Nickvision
TubeConverter.Shared/Models/MediaUrlInfo.cs:line 151
at System.Dynamic.UpdateDelegates.UpdateAndExecuteVoid5[T0,T1,T2,T3,T4](CallSite site, T0 arg0, T1 arg1, T2
arg2, T3 arg3, T4 arg4)
at NickvisionTubeConverter.Shared.Models.MediaUrlInfo.<>c__DisplayClass14_0.b__0() in /home/os/.c
ache/paru/clone/tube-converter/src/tubeconverter/NickvisionTubeConverter.Shared/Models/MediaUrlInfo.cs:line 97
Unhandled exception. System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less
than the size of the collection. (Parameter 'index')
at System.Collections.Generic.List`1.get_Item(Int32 index)
at NickvisionTubeConverter.GNOME.Views.AddDownloadDialog.ValidateOptions() in /home/os/.cache/paru/clone/tu
be-converter/src/tubeconverter/NickvisionTubeConverter.GNOME/Views/AddDownloadDialog.cs:line 498
at NickvisionTubeConverter.GNOME.Views.AddDownloadDialog.FinishSearchUrl() in /home/os/.cache/paru/clone/tu
be-converter/src/tubeconverter/NickvisionTubeConverter.GNOME/Views/AddDownloadDialog.cs:line 482
at NickvisionTubeConverter.GNOME.Views.AddDownloadDialog.<.ctor>b__65_1(IntPtr x) in /home/os/.cache/paru/c
lone/tube-converter/src/tubeconverter/NickvisionTubeConverter.GNOME/Views/AddDownloadDialog.cs:line 118
fish: Job 1, 'tubeconverter' terminated by signal SIGABRT (Abort)
Please, post always your terminal in- and output as text like
Kernel: 5.18.15-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters:
looks like
    parameters:
in forum.
I have edited your post.
Sure !
It looks like this is a bug that was reported last week, and recently fixed:
It sounds like the fix is unique to that beta release at the moment. You can try installing the git version (tube-converter-git), but if that's not working either you'll have to install the beta package as described on their page (either Flatpak or build it yourself):
Another option would be to just wait for the fix to come down in the next release, and use regular old yt-dlp in the meantime.
sudo pacman -S yt-dlp
also , video-downloader is another good options
