Hello, I am having an issue with my garuda linux install. Upon logging in, whether that be on wayland or x11, i am greeted with a blinking tty and occasionally the rare [ OK ] indicating that it finished a process, after logging in. About 30 seconds later it gives me the DE for roughly a minute and logs me out, most of the time to a black screen, and sometimes to the log in menu.
I’m not certain on this but I believe it might be tied to my external hard drive which I’ve encrypted with LUKS. I believe this is the case because the issue sprung up about the same day I did so, as far as I can remember (I’ve been brushing this off for a while now). I’ve tried following some guides online to help me mount it at boot through crypttab and fstab all to no avail.
The issue only happens on initial log in after booting, and sometimes the second log in, on both Wayland and X11, and doesnt happen again as long as the system is on. Unplugging the device at boot makes no difference, and changing the mounting settings from KDE settings in Disks and Cameras makes no difference as well. The encrypted external hard drive is plugged in 90% of the time and leaves the house sometimes, hence why I encrypted it.
Please let me know how I can help you diagnose this issue, as I dont know where to start to be honest, I’ve been on linux for roughly 4 months now. Thanks for your time!
Kernel: 6.9.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=6661e2ff-52e3-4165-8d0e-c97c9468f623 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
wm: kwin_wayland with: krunner vt: 4 dm: SDDM Distro: Garuda
Mobo: ASUSTeK model: ROG STRIX Z490-E GAMING v: Rev 1.xx
UEFI: American Megatrends v: 3001 date: 02/19/2024
Info: model: Intel Core i9-10850K bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 5 microcode: 0xFA
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 4315 high: 4503 min/max: 800/5200 scaling:
driver: intel_pstate governor: powersave cores: 1: 4500 2: 4501 3: 4500
4: 4498 5: 800 6: 4500 7: 4503 8: 4500 9: 4500 10: 4500 11: 4501 12: 4500
13: 4500 14: 4498 15: 4500 16: 4500 17: 4499 18: 4501 19: 4500 20: 4501
bogomips: 144000
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: PNY driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
off: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 01:00.0 chip-ID: 10de:2484
compositor: kwin_wayland driver: X: loaded: nvidia gpu: nvidia
d-rect: 3889x2188 display-ID: 0
Monitor-1: DP-2 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: top-right res: 1969x1108 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: nvidia v: 555.58.02
device-ID: 10de:2484 surfaces: xcb,xlib,wayland
v: kernel alternate: snd_soc_skl, snd_soc_avs, snd_sof_pci_intel_cnl
Device-2: NVIDIA GA104 High Definition Audio vendor: PNY
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
Device-3: Blue Microphones Yeti Stereo Microphone
lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: b58e:9e84 class-ID: 0300
API: ALSA v: k6.9.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 04:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:11 chip-ID: 8087:0026
Hardware-1: Intel Comet Lake PCH-H RAID driver: ahci v: 3.0 port: 4020
bus-ID: 00:17.0 chip-ID: 8086:06d6 rev: class-ID: 0104
Local Storage: total: 1.25 TiB used: 446.35 GiB (35.0%)
model: WD Blue SA510 2.5 1TB size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0100
ID-2: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU600 size: 111.79 GiB
serial: <filter> fw-rev: 1A scheme: GPT
model: WD2500BEVT-00ZCT0 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1.05 scheme: GPT
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
used: 14.46 GiB (13.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-4: /var/log raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.18 GiB used: 512 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 40.0 C mobo: N/A
Memory: total: 32 GiB available: 31.18 GiB used: 6.27 GiB (20.1%)
Processes: 486 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil,upowerd
Packages: 1462 pm: pacman pkgs: 1437 libs: 414 tools: pamac,paru
pm: flatpak pkgs: 25 Compilers: gcc: 14.1.1 Shell: garuda-inxi default: fish
v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-06-24
Last full system update: 2024-07-21
