Trying to swap dock/panel per KDE Activity
I’m trying to clear out my application dock for my other activities and put only specific apps in the other activities. I know Plasma does not let you have different panels per activity, so I figured I could use an activated script to swap the config file. My understanding is that the panel config is in ~/.config/plasma-org.kde.plasma.desktop-appletsrc and I do see the names of the apps I have in my dock. But somehow when switching between activities, even though I have it change a symbolic link to separate config files, when I edit the dock and then switch activities, the changes occur in all of them.
I’m very confused how this is happening. Is the configuration not actually stored in that file?
The reason I am trying to do this, is that per-activity customization of the dock is impossible due to some horrible bugs. If you try to change an application to appear only in one activity by right-clicking on it and changing the pinning checkboxes, and then try to move an app in the dock to a different position, it will scramble the arrangement of everything. Sometimes it gets even more confused and apps will be invisible or visible different from how you actually have the checkboxes set. It’s super frustrating and unusable. So I’m trying to figure out a workaround by just having completely separate configurations for the dock for each activity.
I would appreciate any suggestions.
Kernel: 6.7.0-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e47b5a22-506c-4573-b60f-520b613f7533 rw rootflags=subvol=@
drm.edid_firmware=DisplayPort-0:/edid/Samsung-EDID-RGB.bin ibt=off
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
Type: Desktop System: Gigabyte product: Z690 AERO D v: -CF
Mobo: Gigabyte model: Z690 AERO D serial: <superuser required>
UEFI: American Megatrends LLC. v: F28 date: 12/14/2023
Info: model: 13th Gen Intel Core i7-13700K bits: 64 type: MST AMCP
microcode: 0x11D
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 912 high: 1100 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1100 2: 800 3: 800 4: 800
5: 1100 6: 800 7: 800 8: 800 9: 800 10: 1100 11: 1100 12: 800 13: 1100
14: 800 15: 800 16: 800 17: 1100 18: 800 19: 1099 20: 1100 21: 1100
22: 800 23: 800 24: 800 bogomips: 164044
Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: XFX driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73a5
Device-2: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.1:8
chip-ID: 1532:0e03 class-ID: 0102
Device-3: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.2:9
chip-ID: 07ca:0110 class-ID: 0102 serial: <filter>
Device-4: MacroSilicon USB Video
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4.4:11 chip-ID: 534d:2109
Device-5: Elgato Systems GmbH Game Capture HD60 X
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2.1:4
chip-ID: 0fd9:0082 class-ID: 0300 serial: <filter>
s-diag: 1165mm (45.88")
Monitor-1: DP-1 mapped: DisplayPort-0 model: Samsung serial: <filter>
built: 2021 res: 3840x2160 hz: 60 dpi: 52 gamma: 1.2
size: 1872x1053mm (73.7x41.46") diag: 801mm (31.5") ratio: 16:9 modes:
max: 3840x2160 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6950 XT (radeonsi
navi21 LLVM 16.0.6 DRM 3.56 6.7.0-zen3-1-zen) device-ID: 1002:73a5
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.274 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6950 XT (RADV NAVI21) driver: mesa radv v: 23.3.3-arch1.1
device-ID: 1002:73a5 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.3-arch1.1 (LLVM
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: PreSonus Audio AudioBox USB driver: snd-usb-audio type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12.3:19
chip-ID: 194f:0302 class-ID: 0103
Device-4: Giga-Byte USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
chip-ID: 0414:a00b class-ID: 0300
Device-5: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
Device-6: AVerMedia USB Device driver: snd-usb-audio,uvcvideo type: USB
Device-7: MacroSilicon USB Video
Device-8: Elgato Systems GmbH Game Capture HD60 X
API: ALSA v: k6.7.0-zen3-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-2: Aquantia AQC113C NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: Gigabyte driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 2 port: N/A bus-ID: 08:00.0 chip-ID: 1d6a:14c0 class-ID: 0200
temp: 40.0 C
Device-3: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:22 chip-ID: 8087:0033
Local Storage: total: 16.61 TiB used: 1.45 TiB (8.7%)
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 620331WD temp: 47.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731100WD temp: 54.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:3 vendor: Western Digital
ID-4: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HUS724040ALA640
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: AA70 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HUS724040ALA640
tech: HDD rpm: 7200 serial: <filter> fw-rev: AC50 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: SanDisk model: X110 2.5 7MM 256GB
tech: SSD serial: <filter> fw-rev: 412 scheme: GPT
ID-7: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
ID-8: /dev/sde maj-min: 8:64 vendor: HGST (Hitachi) model: HMS5C4040BLE640
tech: HDD rpm: 5700 serial: <filter> fw-rev: A5D0 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1000.02 GiB (53.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 2.1 MiB (0.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 62.61 GiB used: 271 MiB (0.4%) priority: 100
System Temperatures: cpu: 33.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
mem: 50.0 C
Processes: 523 Uptime: 5h 8m wakeups: 0 Memory: total: 64 GiB note: est.
available: 62.62 GiB used: 7.64 GiB (12.2%) Init: systemd v: 255
Packages: pm: pacman pkgs: 2201 libs: 596 tools: octopi,paru,yay pm: rpm
pkgs: 0 Shell: fish v: 3.7.0 default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.31
Garuda (2.6.22-1):
System install date:     2023-05-03
Last full system update: 2024-01-28
I figured this out. It does work to keep multiple plasma-org.kde.plasma.desktop-appletsrc config files and swap them with symbolic links… I just had a bug in one of my activity scripts and it wasn’t linking the alternate file.
