Hello EveryOne , namaste I am Trying to run garuda with dwm , And TO DO that i installed xorg and edited my .xinitrc but it is not working , here is the error log . Thank you
And I Would Like To highLight This Log: Errors from xkbcomp are not fatal to the X server
Failed to connect to bus: No medium found
X.Org X Server 1.21.1.11
X Protocol Version 11, Revision 0
Current Operating System: Linux hackerman 6.7.1-zen1-1-zen #1 ZEN SMP PREEMPT_DYNAMIC Sun, 21 Jan 2024 22:13:51 +0000 x86_64
Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=c22151da-74d6-4bf4-9f3a-3e098a3c8dc1 rw rootflags=subvol=@ quiet resume=UUID=e2cece78-89ec-4667-b33a-c1f1de9230f4 loglevel=3 ibt=off
Current version of pixman: 0.43.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.1.log", Time: Sun Jan 28 13:23:38 2024
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Could not resolve keysym XF86CameraAccessEnable
> Warning: Could not resolve keysym XF86CameraAccessDisable
> Warning: Could not resolve keysym XF86CameraAccessToggle
> Warning: Could not resolve keysym XF86NextElement
> Warning: Could not resolve keysym XF86PreviousElement
> Warning: Could not resolve keysym XF86AutopilotEngageToggle
> Warning: Could not resolve keysym XF86MarkWaypoint
> Warning: Could not resolve keysym XF86Sos
> Warning: Could not resolve keysym XF86NavChart
> Warning: Could not resolve keysym XF86FishingChart
> Warning: Could not resolve keysym XF86SingleRangeRadar
> Warning: Could not resolve keysym XF86DualRangeRadar
> Warning: Could not resolve keysym XF86RadarOverlay
> Warning: Could not resolve keysym XF86TraditionalSonar
> Warning: Could not resolve keysym XF86ClearvuSonar
> Warning: Could not resolve keysym XF86SidevuSonar
> Warning: Could not resolve keysym XF86NavInfo
dbus-update-activation-environment: error: unable to connect to D-Bus: Using X11 for dbus-daemon autolaunch was disabled at compile time, set your DBUS_SESSION_BUS_ADDRESS instead
/etc/X11/xinit/xinitrc: line 51: twm: command not found
/etc/X11/xinit/xinitrc: line 52: xclock: command not found
/etc/X11/xinit/xinitrc: line 55: exec: xterm: not found
/etc/X11/xinit/xinitrc: line 53: xterm: command not found
/etc/X11/xinit/xinitrc: line 54: xterm: command not found
xinit: connection to X server lost
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
Format terminal output (including your garuda-inxi) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
