Ideapad Gaming 3 15arh7:
Apu: Amd Ryzen 5 6600H with 660M Graphics
Dgpu: Nvidia Rtx 3050 with a 85w tgp(curently set to 60w)
I am trying to get my tdp to this chips full power 60w isnt cutting it for certain games like cyberpunk in particular.
i have tried doing to green with envy and cool bits option… but found out quickly that for some reason that adding an xorg.conf.d file or modifying the orginal xorg.conf config /etc/X11/xorg.conf was a terible idea and keptme from booting…(i had to hop into recovery mode and use maintenance mode to delete said file to be able to boot.
i then had to reinstall nvidia drivers to get my xorg.conf back.) I dont think coolbits is going to work. Or maybe i didnt do something right.
I folowed this for the first time i bricked it .
"jonathonFalconer
(How to set coolbit value on Optimus laptops? - #2 by jonathon)
Firstly, does nvidia-smi work?
Secondly, look for an X configuration file under /etc/X11/xorg.d/ (or as /etc/X11/xorg.conf) and see what its contents is. If you have a file for the nvidia device then you can add Option "Coolbits" "8" into its [Device] section."
Sorry is there is something super simple im missing ive never had an
Hybrid/nvidia gpu on linux and this is also my first distro outside of Fedora.
Kernel: 6.12.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=22611bda-6fee-49b5-a302-1da6617bb7e3 rw rootflags=subvol=@
quiet resume=UUID=8fbf0ae8-6d27-4420-add8-78f98f049d46 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.9.0
wm: kwin_x11 tools: avail: lxlock vt: 2 dm: SDDM Distro: Garuda
Type: Laptop System: LENOVO product: 82SB v: IdeaPad Gaming 3 15ARH7
serial: <superuser required> Chassis: type: 10 v: IdeaPad Gaming 3 15ARH7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76465 WIN
serial: <superuser required> part-nu: LENOVO_MT_82SB_BU_idea_FM_IdeaPad
Gaming 3 15ARH7 uuid: <superuser required> UEFI: LENOVO v: JNCN52WW(V2.12)
date: 10/04/2024
ID-1: BAT1 charge: 43.0 Wh (100.0%) condition: 43.0/45.0 Wh (95.6%)
volts: 13.0 min: 11.5 model: LENOVO PABAS0241231 type: Li-ion
serial: <filter> status: full cycles: 36
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
Info: model: AMD Ryzen 5 6600H with Radeon Graphics bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404107
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1099 min/max: 400/4564 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1099 2: 1099 3: 1099
4: 1099 5: 1099 6: 1099 7: 1099 8: 1099 9: 1099 10: 1099 11: 1099 12: 1099
bogomips: 79053
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo
driver: nvidia v: 565.77 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:25a2 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6,
DP-7, DP-8, Writeback-1 bus-ID: 06:00.0 chip-ID: 1002:1681 class-ID: 0300
temp: 42.0 C
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 13d3:56ff
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.4
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a81 built: 2021
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia x11: drv: radeonsi
inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: amd mesa v: 24.3.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 660M (radeonsi rembrandt
LLVM 18.1.8 DRM 3.59 6.12.8-zen1-1-zen) device-ID: 1002:1681
memory: 500 MiB unified: no
API: Vulkan v: 1.4.303 layers: 15 device: 0 type: integrated-gpu name: AMD
Radeon 660M (RADV REMBRANDT) driver: N/A device-ID: 1002:1681
surfaces: xcb,xlib device: 1 type: discrete-gpu name: NVIDIA GeForce RTX
3050 Laptop GPU driver: N/A device-ID: 10de:25a2 surfaces: xcb,xlib
device: 2 type: cpu name: llvmpipe (LLVM 18.1.8 256 bits) driver: N/A
Device-1: NVIDIA GA107 High Definition Audio vendor: Lenovo
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1640
vendor: Lenovo driver: snd_pci_acp6x v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.8-zen1-1-zen status: kernel-api with: aoss
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network vendor: Lenovo
driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:b852 class-ID: 0280
IF-ID-1: tap-easytether state: up speed: 10000 Mbps duplex: full
mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:4853
Local Storage: total: 1.14 TiB used: 400.12 GiB (34.2%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN580 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 281010WD temp: 53.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: KIOXIA model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 0107ANLS temp: 50.9 C
ID-1: / raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
used: 400.08 GiB (43.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 32.6 MiB (10.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-4: /var/log raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.42 GiB size: 922.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 6.95 GiB used: 1.39 GiB (19.9%)
dev: /dev/nvme0n1p3 maj-min: 259:5
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 43.0 C
Memory: total: 8 GiB note: est. available: 6.95 GiB used: 4.73 GiB (68.1%)
Processes: 373 Power: uptime: 47m states: freeze,mem,disk suspend: s2idle
image: 2.73 GiB services: org_kde_powerdevil, power-profiles-daemon,
Packages: pm: pacman pkgs: 1919 libs: 545 tools: octopi,pamac,paru
pm: flatpak pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
Garuda (2.6.26-1.1):
System install date: 2024-12-30
Last full system update: 2025-01-08
Failed units: NetworkManager-wait-online.service
im just trying to get my full performance out of my card
i dont want to overclock or anything other than fan speed which i can do in green with envy with out coolbits.
can some one help please i have leaving almost 1/3 of my gpus performance on the table.
I did reboot before doing inxi but it has taken me a while to pull my thoughts together in writing this.
lol been working alot im kind of tired
