Trying to install Plasma 6 System is Up to date not on Plamsa 6
λ garuda-inxi
  Kernel: 6.5.9-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
    available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
    root=UUID=9d25b1d7-8596-4137-973a-c4b07f01c28f rw rootflags=subvol=@ quiet quiet apparmor=1
    security=apparmor btusb.enable_autosuspend=n rd.udev.log_priority=3
    vt.global_cursor_default=0 resume=UUID=f1e49dd5-ecee-45d5-9a75-c7129ff3bd3b loglevel=3
  Console: pty pts/3 DM: SDDM Distro: Garuda Linux base: Arch Linux
  Type: Desktop System: Dell product: OptiPlex 7010 v: 01 serial: <superuser required> Chassis:
    type: 3 serial: <superuser required>
  Mobo: Dell model: 0YXT71 v: A02 serial: <superuser required> UEFI: Dell v: A21
    date: 12/21/2015
  Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge gen: core 3 level: v2
    built: 2012-15 process: Intel 22nm family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB
    L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 3471 high: 3579 min/max: 1600/3600 scaling: driver: intel_cpufreq
    governor: performance cores: 1: 3404 2: 3579 3: 3422 4: 3480 bogomips: 25540
  Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics vendor: Dell driver: i915
    v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports: active: none off: HDMI-A-2
    empty: DP-1, DP-2, HDMI-A-1, VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0152 class-ID: 0300
  Device-2: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X] vendor: Micro-Star MSI
    driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 8 ports: active: none off: HDMI-A-3 empty: DVI-D-1 bus-ID: 01:00.0
    chip-ID: 1002:699f class-ID: 0300 temp: 41.0 C
  Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.6:3 chip-ID: 046d:0892 class-ID: 0102
  Display: server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2 compositor: kwin_x11 driver: X:
    loaded: amdgpu,intel unloaded: modesetting alternate: fbdev,vesa dri: i965,radeonsi
    gpu: amdgpu,i915 tty: 143x37
  Monitor-1: HDMI-A-2 model: Sceptre F27 serial: <filter> built: 2021 res: 1920x1080 dpi: 81
    gamma: 1.2 size: 600x330mm (23.62x12.99") diag: 685mm (27") ratio: 16:9 modes: max: 1920x1080
    min: 720x400
  Monitor-2: HDMI-A-3 model: Sceptre F27 serial: <filter> built: 2021 res: 1920x1080 dpi: 81
    min: 720x400
  API: EGL v: 1.5 hw: drv: intel crocus drv: amd radeonsi platforms: device: 0 drv: radeonsi
    device: 1 drv: crocus device: 2 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi
    inactive: wayland,x11
  API: OpenGL v: 4.6 compat-v: 4.2 vendor: mesa v: 23.2.1-arch1.2 note: console (EGL sourced)
    renderer: llvmpipe (LLVM 16.0.6 256 bits), AMD Radeon RX 550 / 550 Series (polaris12 LLVM
    16.0.6 DRM 3.54 6.5.9-zen2-1-zen), Mesa Intel HD Graphics 2500 (IVB GT1)
  API: Vulkan v: 1.3.269 layers: 9 device: 0 type: integrated-gpu name: Intel HD Graphics 2500
    (IVB GT1) driver: mesa intel v: 23.2.1-arch1.2 device-ID: 8086:0152 surfaces: N/A device: 1
    type: discrete-gpu name: AMD Radeon RX 550 / 550 Series (RADV POLARIS12) driver: mesa radv
    v: 23.2.1-arch1.2 device-ID: 1002:699f surfaces: N/A device: 2 type: cpu name: llvmpipe (LLVM
    16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000
    surfaces: N/A
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell 7 driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
  Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X] vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 bus-ID: 01:00.1
    chip-ID: 1002:aae0 class-ID: 0403
  API: ALSA v: k6.5.9-zen2-1-zen status: kernel-api with: aoss type: oss-emulator
  Server-1: PipeWire v: 0.3.84 status: active with: 1: wireplumber status: active 2: pw-jack
    type: plugin tools: pw-cat,pw-cli,wpctl
  Server-2: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa type: plugin
    2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e v: kernel port: f080
    bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2725 class-ID: 0280
  IF-ID-1: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-2: hassio state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IF-ID-3: veth0be2ac3 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-4: veth154100e state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-5: veth3b52ddd state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-6: veth6271b41 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-7: veth63530f6 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-8: veth69b851a state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-9: veth7126455 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-10: vethc672d77 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-11: vethcddd3a9 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-12: vethcff3751 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-13: vethefe13b5 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 0a12:0001 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0 lmp-v: 6 status:
    discoverable: yes pairing: yes class-ID: 7c0104
  Local Storage: total: 931.51 GiB used: 70.85 GiB (7.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
    block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 3B6Q scheme: GPT
  ID-1: / raw-size: 914.15 GiB size: 914.15 GiB (100.00%) used: 70.85 GiB (7.8%) fs: btrfs
    dev: /dev/sda2 maj-min: 8:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 576 KiB (0.2%) fs: vfat
    dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 914.15 GiB size: 914.15 GiB (100.00%) used: 70.85 GiB (7.8%) fs: btrfs
  ID-4: /var/log raw-size: 914.15 GiB size: 914.15 GiB (100.00%) used: 70.85 GiB (7.8%)
  ID-5: /var/tmp raw-size: 914.15 GiB size: 914.15 GiB (100.00%) used: 70.85 GiB (7.8%)
  ID-1: swap-1 type: zram size: 15.51 GiB used: 1.15 GiB (7.4%) priority: 100 comp: zstd
    avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 17.06 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
    maj-min: 8:3
  System Temperatures: cpu: 72.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 2964
  Processes: 431 Uptime: 11m wakeups: 0 Memory: total: 16 GiB available: 15.51 GiB
  used: 6.34 GiB (40.9%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
  gcc: 13.2.1 Packages: pm: pacman pkgs: 2175 libs: 575 tools: octopi,pamac,paru,yay pm: flatpak
  pkgs: 0 Shell: fish v: 3.6.1 running-in: pty pts/3 (SSH) inxi: 3.3.31
Garuda (2.6.17-1):
  System install date:     2023-07-28
  Last full system update: 2023-11-05
 ╭─dgraham@Mulder in ~ via  v16.20.2 took 1s
 ╰─λ
I get nothing to do, I added the chaotic-kde repo which says its up to date but get nothing else.
Figured it out had the repo at the bottom. Mark as Solved
