Hey there,
I've been facing some problems with xdg-desktop-portal recently. Being on wayland I have the xdp-wlr package installed as one should, but still, trying to screenshare in brave yields a crash and doing the same on firefox just shows nothing.
The latter might be related to the fact that apparently no ff-based browsers are compiled with pipewire support, but anyways I am getting these errors in the console:
** (/usr/lib/xdg-desktop-portal:906774): WARNING **: 23:28:52.500: Failed to get application states: GDBus.Error:org.freedesktop.portal.Error.Failed: Could not get window list
XDP: screen cast session owned by ':1.201' created
** (/usr/lib/xdg-desktop-portal:906774): WARNING **: 23:28:57.933: A backend call failed: No such interface “org.freedesktop.impl.portal.ScreenCast” on object at path /org/freedesktop/portal/desktop
XDP: screen cast session owned by ':1.201' closed
** (/usr/lib/xdg-desktop-portal:906774): WARNING **: 23:28:57.934: Failed to close session implementation: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: Object does not exist at path “/org/freedesktop/portal/desktop/session/1_201/webrtc_session123881657”
the WLR package does have support for Screencasting, proven by the point, that it was working fine before and there also being a screencast support line in the wlr.portal file.
I really don't know, what else I can try right now. I have tested this with several browsers, searched a bunch and checked if people had the same issue, of which one was this, but unresolved. I need your help now.
Thanks!
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=6e6211b4-cfb4-44c0-8970-5e4a826e0c5e rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 sysrq_always_enabled=1
iommu=soft
Desktop: wayfire v: 0.8.0-94f15048 info: waybar vt: 2 dm: Ly
v: 0.5.3.r0.g4094d21 Distro: Garuda Linux base: Arch Linux
Type: Desktop System: Gigabyte product: AX370-Gaming 3 v: N/A
Mobo: Gigabyte model: AX370-Gaming 3-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F50a
date: 11/27/2019
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3731 high: 4143 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3563 2: 3202
3: 4141 4: 4132 5: 2838 6: 4143 7: 3023 8: 3500 9: 4002 10: 4101 11: 4019
12: 4109 bogomips: 86228
Device-1: AMD Baffin [Radeon RX 550 640SP / 560/560X] vendor: ASUSTeK
driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8 ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 08:00.0 chip-ID: 1002:67ff
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2:3 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: wayfire v: 0.8.0-94f15048 driver: X: loaded: amdgpu
unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu display-ID: 1
Monitor-1: DVI-D-1 model: Apple Cinema HD Display serial: <filter>
built: 2003 res: 1920x1200 dpi: 99 gamma: 1.2 size: 495x310mm (19.49x12.2")
diag: 584mm (23") ratio: 16:10 modes: max: 1920x1200 min: 640x480
Monitor-2: HDMI-A-1 model: Samsung SyncMaster serial: <filter>
built: 2007 res: 1680x1050 dpi: 90 gamma: 1.2
size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
OpenGL: renderer: AMD Radeon RX 560 Series (polaris11 LLVM 13.0.1 DRM
3.46 5.18.1-zen1-1-zen)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
lanes: 8 bus-ID: 08:00.1 chip-ID: 1002:aae0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Device-4: C-Media USB Microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4:4 chip-ID: 0d8c:9700
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
Sound Server-3: PulseAudio v: 16.0 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-3:4 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Local Storage: total: 2.96 TiB used: 1.46 TiB (49.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A82 scheme: GPT
ID-1: / raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
used: 121.97 GiB (62.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 576 KiB (0.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 736.18 GiB size: 736.18 GiB (100.00%)
used: 188.81 GiB (25.6%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1491
Processes: 375 Uptime: 57m wakeups: 0 Memory: 31.3 GiB
used: 3.68 GiB (11.8%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 2086 apt: 0 pacman: 2069 lib: 536
flatpak: 17 Shell: Zsh v: 5.9 running-in: alacritty inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2021-12-28
Last full system update: 2022-06-06 ↻
