I can't seem to join the Garuda Lemmy instance, it won't let me solve the captcha. I tried refreshing the captcha, and it just opened back the same one. I tried on a different device, same thing. Listened to the audio to double check, pretty sure what I typed in should have been correct.
It's because the second character is a c. Are you a bot? ![]()
Also
- Wrong category. (Was inactive for too long so can't move topics anymore
) - Lemmy Issue
- There is a "Regenerate captcha" button (bruh)
Is it a “c” or an “o”? ![]()
It looks like it is in Web services. That seems appropriate I think, or where do you think it should be moved to?
I think they tried that, but got the same challenge.
I frankly just hate these things, I often struggle with getting past even the most basic ones. “Identify the badly drawn letters” has got to be one of the most frustrating iterations.
For the second letter I tried every single lower case letter a-z, to no avail.
Tried again, the regenerate button still gives me the same captcha ![]()
And I swear, I'm not a robot
beep boop beep boop...
A nice one ![]()
Did you try a 6 (six)?
Oh, well a few hours later and a restart too, it decided to change the captcha. Anyways, problem solved, successfully joined now, time to go explore more of the fediverse!
nevermind. I didn’t notice that garuda got it’s own lemmy instance now ![]()
