My issue has been posted before, and I have followed trouble shooting on those other threads, however those solutions either don't work for me or come back with an error. When my installation attempt is almost done I get the error
grub-install --target=i386-pc --recheck --force /dev/sda
returned error code 1
I'm using a 2012 MacBook Pro (old I know, and can't be expected to be supported across all distros)
I've tried to install other distros and have had mixed results. Endeavour OS had the same error, while Ubuntu, Debian XFCE, Manjaro GNOME, and Pop OS work fine.
I'm moderate novice at the command line, so I have never used chroot or know off hand how to diagnose this issue, but I'm an eager learner so if anyone can lend a hand I'd appreciate it.
Garuda is my favorite distro and had it installed just a few weeks ago, not sure what changed.
Thank you in advance.
Please boot into the live environment, log in to the forum, and paste into the thread the output of garuda-inxi so we can have a look.
filo
31 December 2022 06:33
3
There is a recurring issue with the efibootmgr provided by Arch based distros, called at grub installation time, occurring with some macbook models.
A possible solution (workaround) was found here and , if I remember correctly, confirmed in other topics.
Well I can provide more details.
What I did was I did download debian-live-11.5.0-amd64-kde+nonfree.iso from here: Index of /cdimage/unofficial/non-free/cd-including-firmware/current-live/amd64/iso-hybrid
I Put the ISO image on an USB stick and I did boot my Macbook from this stick.
However WLAN does not work with this image so you need a wired LAN connection on your Macbook.
Then you download efibootmgr by:
sudo apt update
sudo apt install efibootmgr
Then you can modify your EFI NVRAM …
filo:
I tried this method and I received an error when putting
╭─garuda@garuda in ~ as 🧙
╰─λ garuda-inxi
misobasedir=garuda misolabel=GARUDA_GNOME_TALON quiet
systemd.show_status=1 ibt=off driver=free nouveau.modeset=1
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Apple product: MacBookPro9,1 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-4B7AC7E43945597E
Mobo: Apple model: Mac-4B7AC7E43945597E v: MacBookPro9,1
serial: <superuser required> UEFI: Apple v: 426.0.0.0.0 date: 01/18/2022
ID-1: BAT0 charge: 22.5 Wh (100.0%) condition: 22.5/76.3 Wh (29.5%)
volts: 12.2 min: 10.9 model: ifixit bq20z451 type: Li-ion serial: N/A
status: full cycles: 84
Info: model: Intel Core i7-3615QM bits: 64 type: MT MCP arch: Ivy Bridge
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1462 high: 3300 min/max: 1200/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 3300 2: 1200 3: 1200
4: 1200 5: 1200 6: 1197 7: 1200 8: 1200 bogomips: 36719
vulnerable
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
active: LVDS-2 empty: VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166
Device-2: NVIDIA GK107M [GeForce GT 650M Mac Edition] vendor: Apple
driver: nouveau v: kernel non-free: series: 470.xx+
status: legacy-active (EOL~2023/24) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-18 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: LVDS-1
empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 10de:0fd5 class-ID: 0300
temp: 68.0 C
Device-3: Apple FaceTime HD Camera type: USB driver: uvcvideo
bus-ID: 1-1.1:3 chip-ID: 05ac:8509 class-ID: 0e02 serial: <filter>
compositor: gnome-shell driver: X: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa dri: nouveau,crocus gpu: i915,nouveau
Screen-1: 0 s-res: 2880x900 s-dpi: 96 s-size: 762x238mm (30.00x9.37")
s-diag: 798mm (31.43")
Monitor-1: LVDS-1 pos: primary,left model: Apple 0x9ca3 built: 2009
res: 1440x900 hz: 60 dpi: 111 gamma: 1.2 size: 331x207mm (13.03x8.15")
diag: 390mm (15.4") ratio: 16:10 modes: max: 1440x900 min: 640x350
Monitor-2: LVDS-2 mapped: LVDS-1-2 pos: right model: Apple 0x9ca3
built: 2009 res: 1440x900 hz: 60 dpi: 111 gamma: 1.2
size: 331x207mm (13.03x8.15") diag: 390mm (15.4") ratio: 16:10
modes: 1440x900
Device-2: NVIDIA GK107 HDMI Audio vendor: Apple driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:16b4 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Broadcom BCM4331 802.11a/b/g/n vendor: Apple AirPort Extreme
bus-ID: 03:00.0 chip-ID: 14e4:4331 class-ID: 0280
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb
v: 0.8 bus-ID: 2-1.8.1.3:9 chip-ID: 05ac:821d class-ID: fe01
Local Storage: total: 506.83 GiB used: 6.37 GiB (1.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 PRO 512GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: PNY model: USB 2.0 FD
size: 29.89 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-1: swap-1 type: zram size: 7.7 GiB used: 485.8 MiB (6.2%)
System Temperatures: cpu: 78.0 C mobo: N/A gpu: nouveau temp: 68.0 C
Processes: 273 Uptime: 21m wakeups: 4 Memory: 7.7 GiB used: 1.97 GiB
(25.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1134 libs: 314
tools: pamac,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-12-31
Last full system update: 2022-12-31 ↻
To install in arch you have to use
sudo pacman -S "package-name"
I used that command in the debian live environment per that users post for his solution. I think it was package not found.
filo
31 December 2022 15:03
8
Strange, that's a very common package.
Have you given a sudo apt update before?
Maybe try again and check the spelling.
Also make sure that internet connectivity is available in the live USB. Best thing is to use an ethernet connection or mobile phone tethering.
8h
I can try again, but I'm certain it was spelled right. I was using mobile tethering at the time. Strange to me that manjaro calemaris installer works. Fedora fails to install however.
In the meantime I'm dual booting mac OSX and POP OS. I may try garuda manual partition over pop os since I had to create a seperate EFI partition than the Macs'.
So I think I'm on the right path. Can't find a way around fixing the missing libcrypto.so.1.1 issue.
SGS
4 January 2023 22:00
11
Please, never post picture from terminal, just copy and paste here as text.
With 3 ~ in first and last line
Terminal text
then others can easily expand or copy the text.
terminal text
then others can easily expand or copy the text the view. Move the mouse pointer over it in the upper right corner.
BTW, is this from a live ISO session?
filo
4 January 2023 22:09
12
That looks like the Garuda live USB, while the suggested procedure was based on a Debian live USB, installing there efibootmgr and using it to create the EFI boot entry for the Garuda system you already installed and failed at the end.
Maybe this is the reason for the troubles in installing efibootmgr, since you cannot use Debian commands on Garuda.
system
Closed
18 January 2023 22:09
13
